Question about NetGear Computers & Internet
Hi I am tring to get a firmware update for the DG834GU v5 modem but i cannot find a GU version so I tried theDG834Gv5 and saved it, but when I go to Browse and choose the file a Get a warning about only using trusted stuff, Please can you give me a Link to the Software update for the DG834GUv5. Kindest Gregg Cornell gc34@mweb.co.za
5 Suggested Answers
asood23
  • 200 Answers
SOURCE: i have a dg834gu v5 router from optus australia
Download the drivers here.
Posted on Sep 20, 2009
Coastsider
  • 331 Answers
SOURCE: how do i pair my iphone to my netgear router? the
Are you trying to connect WIFI? "pairing" is a bluetooth function. If the router has not already been configured for WIFI, then your iphone should see a local wireless network called Netgear. You should be able to connect to it with your iphone simply by selecting it and answering the security question. If it has already been configured, you should make sure it was setup for WPA or WPA2 (NOT WEP) When it was configured, it should have been setup with a passphrase (key code, encryption key) which you need to intially provide on your iphone to make the connection. Its pretty straight forward.
Posted on Apr 16, 2010
  • 4 Answers
SOURCE: I have a Netgear DG834GU
Press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
Use this method for cases when the administration password or IP address is not known. These steps restores the router setting to factory defaults. (e.i. administration password to admin and the IP address to 10.0.0.2.
eds6524
Posted on Jan 11, 2011
shashank1990
  • 125 Answers
SOURCE: MINE IS A NETGEAR DG834GU V5,INTERNET KEEPS ON
There are many reasons why this might be happening.. You could try the following steps..
First connect the modem directly to the computer and see of the problem persists..if yes contact your internet service provider..if the problem doesnt show up with modem then please follow the below steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Posted on Feb 07, 2011
GLB-802C new firmware
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Feb 08, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Which is the latest firmware update for the 2540U Router? http://ftp.dlink.ru/pub/ADSL/DSL-2540U/Firmware/ is the only site I can find with updates on it but I'm not sure which to choose.
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Apr 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
MINE IS A NETGEAR DG834GU V5,INTERNET KEEPS ON CUTTING AFTER ABOUT 10MINS FROM REBOOTING.WHATS THE PROBLEM
Hope this helped
Feb 07, 2011 | NetGear DG834G Router
I have a Netgear DG834GU v5 modem and have forgotton the password for Wi Fi, I wish to use it on my ipod. Could you help me find a solution? Regards Nat
eds6524
Jan 11, 2011 | NetGear DG834G Router
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
This modem does not save settings. Like when you open your nat. How do i update my firmware
Check the latest firmware updates at www.belkin.com/support.
Or simply, access the setup page of the Belkin router (192.168.2.1), go to Utilities > Firmware update. Click on the Check firmware button.
Then click the download link. And save the firmware on your desktop.
In the firmware update screen, click browse and locate the firmware from your desktop.
Then click the Update button. Click OK to continue with upgrading.
I hope this helps!
May 15, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
BELKIN ROUTER F5D7231-4 TCP PORT 1723 BLOCKS VPN CONNECTION
Download the latest firmware from: http://belkin.com/support
Upon searching, you will three versions of this model available. As you didn't specify the version, you may select the appropriate.
Download and save it your desktop
Open router interface using: 192.168.2.1
Under utilities, click on Firmware Update
Browse, Locate the file(.bin) from your desktop, click on update
Click on Restore Factory Defaults under Utilities
Try to re-configure the router and forward ports that you want.
If this doesn't work, Enable DMZ for the private IP address you want.
That should certainly work.
It could also be your modem that may be blocking> Check this too
Only if you have NAT enabled modem, try to use this router as an access point
This would surely work
Jan 15, 2010 | Belkin (F5D7231-4) Wireless Router
I think my router needs upgrading because the connection keeps going down and knocking me off explorer and firefox it did this before i had to ring aol because my unit had reset itself to basic mode and...
What you can do before purchasing a new router is to try updating the firmware on your modem. The firmware can fix minor "bugs" or "malfunctions" that a device can have. You can go to the link below and try updating the firmware. The information you'll need to ensure you download the correct firmware is the "version number" of your modem. On the bottom of you modem there should be a "DG834G" with a "v" then a number. That is your "version number". If you need any further assistance, please let me know.
Jul 31, 2009 | NetGear DG834G Wireless Router
Computers & Internet Logo
598 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
