Question about Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER
Heater will only go up to 89 degrees.. using the remote. do i need to set the temp at the main heater
  • 31 Answers
The temp at the heater should be set to maximum when using a remote. The remote can only go as high as the thermostat setting on the heater.
Posted on Apr 18, 2011
Master Temp 400 reading 32 degrees on LED read out and the remote control is reading 62 degrees. What can cause the difference?
The control panel has its own temp sensor which is a probe into your plumbing. It's typically found between the pump and the filter and is held on by band clamps.
The heater has its own temp sensor found on the header manifold area.
i doubt the water is 32 degrees so I assume the heater temp probe is bad, it needs to be replaced, it's plugged into the circuit board and threaded into the header of the heater.
The two sensors should match or be within one degree of each other for ideal operation.
The reason they have separate temp sensors is to protect the system.
Nov 26, 2016 | Pool & Spa
Jandy panel reads 89 degrees, sta rite heater panel reads the right temp 78.
Standard 10K ohm sensor appears to be compromised. Replace it.
You have one for water temp, one for air temp, and one for the solar if you have one.
Feb 14, 2014 | Jandy Pool & Spa
Febo Electric Fireplace Insert Using remote It Will Not Auto Shutoff when room reaches temp. also If room is Cold & Temp is set higer it will not turn on. U have to manually shut it if or on. there is...
Maybe its the fireplace's ignition spark box at the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Oct 24, 2013 | Leisure HOMEPRIDE Electric Fireplace...
My pool heater comes on when the filter pump is on altho the heater is not programmed to do so
could be a communication problem from the main control system box. for most remote systems, heater temp on control pad must be set to max 104 in order for control box to control everything. if temp is not set to 104, main remote controls will not override manual tstat on heater
Oct 09, 2013 | Jandy AQUALINK RS TELELINK KIT
Why does pool heater come on when filter pump is turned on?
some models the heater will overide the remote. put heater temp to highest setting 104 degrees, then remote should override the heater
Nov 20, 2012 | Jandy Aqualink Rs4 One Touch Control...
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Apr 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER Logo
95 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
