Question about Garden
Hoffman ge 7000 two post screw type hoist. lifts,ok/chatters,locks up when trying to lower,seems to be safety lock device .how to fix. thanks for the help
Any answers on the hofman hoist having the same problem
Posted on Aug 30, 2014
What safety tips should I follow when using lifting hoists?
Lifting hoists are tasked with the pivotal job of lifting heavy loads that would otherwise be rather impossible to lift. Used in many industries worldwide, there are various safety tips and guidelines one should follow thoroughly, to ensure both the safety of the workers, and to extend the lifting hoist's lifespan. The equipment should first be inspected before and after every use, so as to make sure there are no defects and that the equipment is clean, as slight issues with the equipment could be dangerous if left unattended for any period of time. One should also always be aware of the lifting load limit of the lifting hoist and comply to this limit - never, for any reason, exceed this limit! This can be extremely dangerous, as placing too much strain on the lifting hoist can cause it to break. These are just a couple of the number of factors that could cause a normally sound piece of equipment to be dangerous. To find out more on this topic, this handy infographic from Lifting Hoists Direct, titled "Safety Tips for the Effective Use of Lifting Hoists" was helpful in answering all my questions.
safety tips for the effective use of lifting hoists infographic (final)-3lnz3eczbu0rpnl5hmzvm3sh-2-3.jpg
Sep 13, 2017 | Cars & Trucks
Need to calculate thickness of wood needed for a span across two posts, posts would be 100mmx100mmx2000mm, top piece of wood would need to be 2000mm between posts with a v8 5 litre engine hanging off
What type of wood, which way is the grain going, how many knots in the wood? Normal safety factors double the load weight so you should plan for a 1100kg load (Approx 1.25 US tons). Wood is not really a predictable load bearing item and you want it over a 6 foot wide gap with a potential of just over a ton in the middle? Yes you can make calculations if you know your material but even the uprights at 4ins square seem rather small.
Feb 07, 2017 | Cars & Trucks
How to unfold a safety first playpen
Most all of the newer playpens called Pack N Plays use a bottom-center
safety device. You must lift up the bottom of the playpen, usually a tab or twist handle. Either lift or twist and lift to be able to drop or raise the sides. YOU CANNOT RAISE OR LOWER THE SIDES UNLESS YOU LIFT THE SAFETY UP. Dont man-handle the sides. Slamming them up or down will break them. Sometimes it helps to lift the side releases before pressing the releases thet are inside the cloth. Basically the floor of the playpen has to be sticking up to allow the sides to raise or lower and lock.
Feb 12, 2012 | Baby Gear
How do I replace my rear bumper on my 04 pacifica
  1. Open liftgate.
133387935 Fig. 12
  1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
  2. Hoist and support vehicle with safety stands, as necessary.
133387936 Fig. 13
  1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
  2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
  3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
  4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
  5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
  6. Place fascia on a clean surface.
133387937 Fig. 14
  1. Remove park assist sensors, if necessary (Fig. 14).
133387938 Fig. 15
  1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
  2. Using a trim stick release locking tabs and separate the upper and lower fascia.
133387939 Fig. 16
133387940 Fig. 17
  1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
  2. Remove molding from fascia.
INSTALLATION
  1. Place bright chrome molding in position on the upper fascia.
Jan 06, 2012 | 2004 Chrysler Pacifica
Dough blade is scraping the stainless bowl. The mixing head seems to be sitting lower. In order to lock the tilt I have to lift the head a little.
If you're still having this problem, here's what I did a few minutes ago that fixed it. Lift the head, then turn the screw that connects the head to the base to the left. You're basically unscrewing it. That screw regulates how high or low the beater is. Unscrew it a little at a time, and lower the head and try to lock after each turn. The head will gradually get in a more locked position. Keep turning the screw till the head finally locks in all the way. Read the "beater to bowl clearance" section in the manual.
Nov 20, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Spare tire won't release.
This is the worst GM engineering i have ever seen !!!! The secondary locking mech. rust itself in the locked position on will NOT allow the tire to lower. After lowering the tire down approx. 2-4" the saftey lock is still engaged. I was able to reach above the tire and remove the bolt holding the hoist in place. {15 mm wrench}. Keep a floor jack under the tire to support it and as not to fall on your head. After removing the bolt the hoist is hooked on the frame member and must be lifted off to remove. Once you get it on the garage floor it is possible to disengage the locking mech. with a few tools and a big hammer. Good luck This should be a Recall
May 20, 2009 | 2005 Chevrolet Silverado
Tire hoist will not lift back up.
no the hoist must be replaced, they are famous for this, all trucks use the same one.
May 12, 2009 | 2002 Chevrolet TrailBlazer
Passenger door lock removal
hello,seems you have a sticky siding maybe because of plastic clips,try to insert a plastic wedge siding and door,pull the lower part and lift a bit,observe the movement of siding,how about the screw in lower armrest,press off the cover,then look for screw,be sure no screw are fitted,ty
May 02, 2009 | 1996 Mercedes-Benz C-Class
Ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Chevy pick-up spare tire hoist won't release
Sugerinimo's idea is good but I good not get it too work.. Well, this can be easier or a bit harder. Mine was harder. You are stuck on the secondary tire lock. There is a process in your manual that involves lowering the tire as far as it goes with the secondary lock, then placing your tire jack under the center of the tire holder and jack it back up until its tight to the frame - this should release the secondary lock. In my case this did not work. Plan B, is grab a 15 mm socket, small extension and ratchet. Lower the tire as far as it goes. Locate the 15mm bolt that attaches the tire hanger to the frame, undo the bolt, the hanger is then swinging from the back, lift up the tire and bracket and it will fall off. be careful the tire is heavy.
Next on the top of the tire you will see a rubber cover the secondary lock slides into. Pull down the boot. You will see two holes along the bottom on the opposite side to the crank. Turn the bottom part of the lock. If you look in the holes you can see where the catch is. Take a slot screw driver and hammer, line up the catch and tap it back in.
The secondary lock is now free.
Remember when reinstalling the bolt on the frame to use some locktite.
Mar 14, 2009 | 2003 Chevrolet Suburban 1500
Garden Logo
486 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
