Question about Maytag Ovens
Hello - I have a Maytag Performa electric range MER5752BAW. The stovetop works fine. However any feature related to the touchpad doesn't work. The oven, self cleaning, broiler, etc... doesn't work. The clock works fine. When we try to broil or start the oven, it initially looks like its ok but after 2 seconds it goes back to showing the time.
  • 4 more comments
  • nmdj94 Apr 10, 2011
    thanks - so i need to purchase a burner switch. is there a specific one or is it universal?
    it's not an issue with the burner - it's the oven
    thanks - is there a way to check to see if its the sensor w/o buying a new one?
    thanks - the temp sensor is working fine. i'll contact you once i've purchased a touch panel.
  • nmdj94 Apr 13, 2011
    Thank you so much. we ordered a new touch pad and now the stove works. I really appreciate it. thanks again!!!
  • 5,370 Answers
Check the oven temp sensor. Inside the oven sticking out of the back wall is a metal rod it is the oven temp sensor.
You can do this. Unplug the stove. It is held with two screws inside the oven. Pull the stove out remove the lower back panel to undo the connector and check the Sensor.If sensor is faulty, then it will not let the broil function to start or heat.But if that checks out, ok, then it can be problem with touch pad panel.Its got faulty and getting short.So the oven starts and trips inside and timer resets and shows time.------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Check out.Keep updated.Thanks.Helpmech.
Posted on Apr 10, 2011
  • 1 more comment
  • raj somaiya Apr 10, 2011
    Testing it with meter can be done.-------Disconnect the sensor plug and then insert one meter lead into the terminal of the temperature sensor plug and place the other meter lead into the other terminal of temperature sensor plug. Place the dial on your multimeter to 200K .
    You will need an ohm meter to test the sensor, most oven sensors should read about 1100 ohms at room temperature 60 - 80 °F (15 -27 °C), if the sensor reading is 'open' or extremely high this means the sensor is faulty and needs replacing, if on the other hand the reading is extremely low then the sensor has shorted (check for wires touching each other) and will need replacing as well.----------- this should help.Thanks.Helpmech.
    Yes, this should help.Keep updated.Thanks.Helpmech.
  • Patrick
    Patrick Jan 13, 2014
    I have a double oven which does the same thing...niether will turn on
    Brigadier General:
  • 3,917 Answers
In your case burner switch needs to be replaced.These switches operate like regular dimmer switches. By regulating the amount of electricity flowing through the switch to the burner they allow you to adjust the temperature setting, if you can't adjust it then the switch is bad. I suggest you get a new one from the parts supply. They aren't hard but you need to decide and let me know, but it really is simple if you can unplug wires and plug new ones in and turn a nut to get the switch off your probably capable of this repair your self.
Thanks
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
We have a maytag oven. all the buttons work except for the bake and light button.Mod # umc5200aaw
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
Jul 06, 2011 | Maytag 30 in. Electric Single Wall Oven...
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean"...
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Apr 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
326 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
