Question about Bernina Virtuosa 160
The humming noise the Bernina 350 makes when first turned on, doesn't go away when the machine is not in use. Otherwise, it sews well, and doesn't have any other issue. Just that very loud annoying sound.....
  • 89 Answers
Is your bobbin winder on?
I get that one in my shop about 1-2 times a mounth.
Posted on Apr 11, 2011
  • dsantora
    dsantora Aug 06, 2017
    Had the same issue-- had just come home from a machine tune-up and had the humming noise when I turned on when I got it home.....was ready to take it back to the shop! Thank you!!.
  • Anthonia Onwordi
    Anthonia Onwordi Sep 01, 2017
    Thanks for the tip, Nathan. I panicked when my new 380 started buzzing as soon as I turned it on.
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Apr 08, 2017 | Bernina Sewing Machines
My bernina aurora 440 sewing machine is making a high pitch humming noise when I turn it on
These machines do make a noise during start-up, but if it stops after the sewing machine has gone through the set-up, it is probably okay. However, if the noise continues, it should probably be taken for a check-up. Even so, if you are worried, a check-up may still be helpful.
Feb 12, 2017 | Bernina Sewing Machines
The power switch is bad on my bernina sewing machine
I would suggest taking the machine to a sewing machine repair shop, since it's a Bernina.
Nov 10, 2014 | Bernina Artista 170
How do I keep the walking foot from unscrewing the needle holder on my bernina record 730
I don't know about bernina but I will take a shot at your problem. Make sure your needle is inserted in the needle arm with the flat part of the needle facing away from you. After it is for sure inserted in the crack in the arm tighten the needle down firmly. If the needle is backwards it will continue to come out. Your machine might sew but it will possibly make noise when the needle is in the down position. The problem isn't the walking foot.
May 22, 2014 | Sewing Machines
I have a new Bernina 350 and the bobbin doesn't wind on evenly. If left to do it automatically it ends up wrapped around the bobbin spool. Is this normal?
the thread has to be pretty tight around the bobbin tension guide
but I would suggest if you can't get it to wind correctly to have it check to see if there is a problem with it
May 12, 2012 | Bernina Sewing Machines
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean under the needle plate
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Aug 03, 2011 | Sewing Machines
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
Jul 27, 2009 | Bernina Virtuosa 160
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
1,027 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
