Question about Speed Queen Washing Machines
Hello... Have a SPEED QUEEN Washer # HA4591L shaked vigourously for a while, then would only do partial loads while shaking, then stopped working all together. Any suggestions? Thanks in advance.
    Brigadier General:
  • 6,277 Answers
Balance it
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 11, 2011
How do i take agitator out of speed queen awn412 washer
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Aug 25, 2011 | Speed Queen AWN412 Top Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
My Speed Queen washer shakes and walks during the spin cycle. I have leveled the machine and ajusted the amount of clothes in subsequent loads and it still shakes. How do I solve this? Thank you!
Did you remove the shipping bolts from the back of the washer? They are located on the back, usually very clearly marked "REMOVE" and have a red or yellow plastic washer/bushing. This is a fairly common problem with front load washers, from what I understand.
They're big suckers, and they keep the drum suspension from absorbing any vibration (so the drum doesn't slam around during shipping). Good luck!
Jan 27, 2011 | Speed Queen CTSA0AWN Front Load Washer
Model CTS90AWN Speed Queen from Alliance Laundry Systems. The unit shakes / vibrates quite a bit - I have read that this is a common problem. Also leaks a small amount of water from beneath unit (have not...
These machine like to be loaded to capacity. Under loading them is the major cause of shaking. Try loading the drum all the way lightly filled but not packed. Another thing to look for is that it was installed properly. It is very important with theses machine that they be leveled properly at install. If this was not done shaking can occur.
Dec 27, 2010 | Speed Queen CTS90AWN Front Load Washer
The outlet hose on my classixx 1000 seems to have a blockage
FILL DRUM WITH HOT WATER FROM A JUG SHUT DOOR AND PUT ON SPIN REMOVE HOSE FROM OUTLET AND PUT IN BUCKET OR SINK ACTIVATE SPIN AND SHAKE AND STRETCH THE HOSE VIGOUROUSLY THIS WILL SHIFT DEPOSITS KEEP DOING IT TILL WATER RUNS CLEAR MAKE TAKE A WHILE.
Jul 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Shake when spins even when no clothes in it
Make sure the lags are solid to the floor. Any bit of difference will be exagerate when the washer spins. put a piece of paper under each of the front legs. While the washer is spinning try and pull the paper out. If you can pull the paper out with no problem, that leg needs adjusted to the floor more. If Ican help further, please let me know
THanks
Vic
May 15, 2009 | Speed Queen ATS90AWN Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer shakes on spin cycle
2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
2 check the suspension legs at the base of the tub for wear or damage.
Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Charles T Nevin
Charles T Nevin
fordexpert
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
