I have wash machine gorenje 61101. After it has reached temperature (90C) it stops (with water). Green and yellow light switched at same time 7 times than stopped, and switch again. Can you help me?
SOURCE: LG Intellowasher 7.2kg WD80130F
where is the drain filter located
Posted on Mar 11, 2008
SOURCE: Washing machine wont stop filling up
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
Posted on May 29, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
  • 30 Answers
SOURCE: My new washingmachine (just 1 wash) stinks like
send it back under warrantee.
could just be motor settling in.
dont take a chance
Posted on Feb 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: no gorenje user manuals for washer 61101 on internet
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Gorenje with error code 7 what is the problem ?????
Error 7 and water inside drum. Sock stucked under tank blocking water to go out. Turn off watter and power, drain washing mashine manually through filter, remove back and bottom cover, remove 2 tube clips from black flexibile thick tube and remove any subject except ball in elbow. You need just screwdriver, muscles and some time. Good luck.
Apr 18, 2011 | Washing Machines
I wander what is the normal temperature range for M.E200,1998?
80C. Summer time city driving, it reaches 90C from time to time. It's OK.
I would check a few things if goes over 90C. These things are simple ones...
- level of coolant
- activation of fan 110-120 IS TOO HIGH!
Dec 13, 2010 | 1998 Mercedes-Benz E-Class
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Stopped working during a wash
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
-high temp wash
-heated dry
-high temp wash
-heated dry
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
