Question about Dual Computers & Internet
Do not start and dont up system - Dual Computers & Internet
  • Dual Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 10, 2011
How to turn off faulty alarm system on 2006 corolla so that car will start
sounds like you also killed the immobilizer too, now are immobile.
CRANKS BUT DONT START right, and IMMO blinks ?
the IMMO light tells you ,what ITS doing, watch it.
the thieft and immo are very complex in the toy world.
before hacking it , find out how,.... the top answer is , you cant.
so which is first. the thieft sys. or immo.?
first read this, after checking all fuses in both fuse boxes
http://qcwo.com/technicaldomain/toyota-corolla-immobilizer
dont loose the master, key or use id daily
dont have 2 keys in car. at same time.
dont have other keys on right blocking the magic RFID key.
dont mess with it, if you mess with it , it THINKS you are crook
so dont.
it may also IMMO lock out if the theft system is hacked.
ill let you goggle that.
Jan 15, 2014 | 2006 Toyota Corolla LE
My gsx600 katana. donT WANT TO START. SEEMS LIKE THE GAS DONT GET IN TO OR GET IN TOO MUCH AND DONT LET IT START IT, WHAT IT CAN BE?
If the bike has been sitting for any period of time, maybe 6 months or more, the carbs and fuel system probably needs cleaning. Remove the carbs and have them cleaned or take the bike in for a complete fuel systems servicing. Carb cleaning can be rather detailed and should be left for the professionals unless one has experience.
Feb 20, 2013 | Motorcycles
Securyty ligth car dont star
ANY TIME SECURITY LIGHT COME ON YOU HAVE FAULT IN THE IGNITION KEY OR KEYS THEY COULD BE WORN OUT WHERE TO A POINT WHERE THE BCM AND PCM DONT RECOGNIZE THE CAR KEYS CAUSING NO START CONDITIONS.ALSO WORN KEY SWITCH AND BCM WILL CAUSE NO START CONDITIONS.TRY THESE TWO THINGS TRY ANOTHER CAR KEY IF STILL DONT CRANK.PUT KEY IN IGNITION TURN KEY TO ON POSITION WITH ENGINE OFF LEAVE KEY ON POSITION IN IGNITION FOR 10 MINUTES WATCH DASH SECURITY LIGHT WHEN IT TURNS OFF IN 10 MINUTES.TURN OFF IGNITION FOR 5 SECONDS THEN TRY STARTING CAR IF CRANKS OR DONT STILL THE PROBLEM IS IN THE THEFT SECURITY SYSTEM NEED TO GET DEALERSHIP TO FIX THEY HAVE DIAGNOSTIC EQUIPMENT TO FIX AND REPROGRAM THEFT SECURITY. SYSTEM.
May 25, 2010 | 1999 Oldsmobile Alero
2001 gallant will not start
Start by checking your fuel system. Often when this happens its due to an obstruction in your fuel or air systems. It could be as simple as a clogged fuel filter or a faulty fuel pump.
Jun 08, 2009 | 2001 Mitsubishi Galant
I want drivers for my system but i dont know about motherboard
Go to Windows start menu, all programs, accessories, system tools, start system info tool.
Mar 27, 2009 | ASUS P5VD2-MX SE Motherboard
My van dont start because the alarm sistem is on.
turn the ingnition on and you should have a hidden disarm switch or button under the steering column
Mar 26, 2009 | 1996 Chrysler Town & Country
94 crown vic remote start??
you will not need anything else. If your not planning on doing it yourself than you will need to bring it to a shop to have it put in. This car is pretty system install. You can obtain a wiring diagram for it and put it in yourself. But if not you will not need anything else for this vehicle
Feb 20, 2009 | Valet 561T Remote Start Module
My pc dont start
The problem identified that your system wont start. By solving, let begin from the very the very start. 1. be sure that power supply function well. u can test PS by changing temporary identified functional PS. if u sure that PS is good then, examine processor. remove memory. switch on system w/out memory if hear beeping. u are sure that processor is working.if not then something wrong with your processor. if beefing then insert memory. if not solve, examine memory clean it very well. and insert. if same problem replace memory. notify me if more problem identified. we will continue.....
Dec 14, 2007 | Systemax Venture PC Desktop
Computers & Internet Logo
59 people viewed this question
Top Dual Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Dual Computer and Internet Expert? Answer questions, earn points and help others
