Question about Hitachi Televison & Video
I bought a second hand hitachi tv and there was no remote i want to fix the color
We were given a used hitachi 46UX13k....no real color and so we needed a remote. I went to Walmart and purchased a RCA remote - about $18 that I could program for it. It works, but I am still unable to get color.
Posted on Aug 07, 2008
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
I have arear projection Hitachi big screen that has an unlevel picture. Crooked a bit. How can I manually fix this?
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
Jul 17, 2011 | Hitachi 61SWX10B 61" Rear Projection...
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hi my son got a 19inch emerson tv for his 2nd birthday and now anytime it gets plugged in it flashes different colors and the buttons does't work and the only way to turn it off is to unplug it!! can this...
Press the the cursor key up followed by down and power the TV off with the remote or the TV itself. Please use the original remote for this. Unplug the TV for a few seconds...replug and power the TV on. The second thing to try...press the cursor key left followed by the right key. Power the the TV off with the remote or the TV itself. Unplug for a few seconds...replug and power up the TV. Some of these TVs left the factory in the service mode. The fix is pretty simple. Thanks asking and show a few hands of support!
Feb 14, 2011 | Emerson LC195EM9 19 in. LCD TV
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
42 inch hitachi projection tv. green tint told it might be color wheel
sounds like your picture color tube may have went if the tv can not be adjusted with the remote or on the tv itself did you try every color or picture button on the remote and the tv itseff and if it is old i would get a new one if not have it fixed , sincerely john
Aug 01, 2008 | Televison & Video
Hitachi 50V500 TV: has a red line that outlines faces or text
It's a light engine defective part. Hitachi knows about it and if you call their customer relations department, they will refer you to a dealer in your area to come and diagnos the problem. Once Hitachi can verify that's the problem, they will ship the part to the dealer. We had our part in 2 days and had it installed today. No more problems. TV looks brand new. We had to pay the installation of $400 but the part runs around $1500 and Hitachi covered it. We felt like $400 was worth the $3600 we bad 3+ year ago when we bought it. The color will only get worse if the light engine is not replaced. Good Luck! It was an easy fix!
Nov 17, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
