Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
  • 963 Answers
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Posted on Apr 18, 2011
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
The keypad stopped working. I replaced the batteries and it beeps, but the keypad is still not working - random beeps, but when I try to reset there is no response.
I did not find any direct information or solutions on the Kwikset web site, so I suggest that you contact them directly. Here is the contact link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Feb 10, 2011 | Kwikset 90711P Venetian Bronze SmartCode...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Why doesn't the back lights work on my Kwikset 907 Power 1000 Keyless Entry Deadbolt? Are there any other batteries beside the four 1.5 alkaline batteries?
Installation instructions for the Kwikset 907 link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
This is the link to Weiser Customer Support Page, where you will find the appropriate number for your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Oct 21, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I installed the Kwikset 907 model last night and it was working fine. Tested it several times, showed the family, etc...Everything worked great. My son left for 10 minutes and came home and it no longer...
Why is my Powerbolt beeping?
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Good luck--and please provide feedback if this helps!
Oct 11, 2010 | Kwikset 907 907-15 Satin Nickel Smart...
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
1,139 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
