Question about Garden
I bought a Bernina sewing machine in USA but I took it to Colombia South America. The machine works well, but it makes noise when not in use. When you turn on the machine, there is a normal "humming" sound that its supposed to be only when its turned on; however, it keeps making that sound when the machine is on standby and not sewing. When the machine is sewing it doesn't make this sound, but the natural sewing machine sound. I don't know how bad it is, because the machine works perfectly fine otherwise. I just don't want to keep using it like this, if there is indeed some issue with the machine, that I could keep doing further damage.Any insights would be appreciated. Thank you!
    Problem Solver:
  • 8 Answers
I also might be something very simple. It might be that your bobbin winder is one. Some Berninas have a separate bobbin widing motor. isf the lever on the top of the machine is pressed to the left your bobbin winder will turn on even if you aren't winding a bobbin. Push it to the right and it will turn off..... and your humming should go away.
Posted on Apr 21, 2011
    Novelist:
  • 155 Answers
Generally humming sounds from electrical devices are transformers. If the machine has a transformer in it.. which is a device that changes the voltage stepping it down to a lower voltage or up to a higher voltage.. these transformers which are tightly wound coils of copper wire.. tend to hum.. same situation as an overhead fluorescent lamp fixture.. sometimes louder if the mounting screws are not tight or insulated with rubber washers.
Since the sound doesn't change.. my guess is that while in standby mode the current is still being supplied to this transformer..
I doubt you are doing any damage.. However the best thing you can do is check the voltage at the outlet to ensure you are gettting a true 110V and that the outlet is properly grounded. You need a ciruit tester to check for proper grounding.. they are inexpensive... but you will need a volt ohmn meter or similar device that can display voltage to check for proper voltage.
Low/improper voltage can be harmful to many eletrical devices.. So have it checked.
Finally..if the sufrace the machine is sitting on lends itself to amplify the sound.. vs. the surface you used in the states.. it would be much more noticable..
Best of luck
Posted on Apr 10, 2011
Benina foot pedal doesn't work
type in browser sewing machine parts in panama central america & see what comes up
or if you have a phone directory check for sewing machine shop & see if they can order one
Mar 09, 2012 | Bernina Artista 180
I just bought a used Bernina 150 and the stitching is great but it is making really weird noises like a shaker squeking noise when I go at top speed.
I think this is an indication that you need to oil your machine. Follow the directions in your user's manual. Use special sewing machine oil that is clear and available from sewing shops. I also think it is best to clear out any fluff (lint) before you oil your machine.
Aug 21, 2010 | Bernina Virtuosa 150
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Dec 30, 2007 | Bernina Activa 130
Sewing machine
my machine will not sew what do i do??
Jan 23, 2007 | Yamata FY900 Mechanical Sewing Machine
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
