Question about Nikon COOLPIX L20 Digital Camera
The camera will not power on even when I change batteries nothing happens.
  • 129 Answers
Something wrong with points where the batteries attached.Clean them may be work.If not you must get it to repair center or service center.
if cleanning is solve your problem.then remember that when you going to not use your camera for a week.remove battery from it because the battery chemical get out form battery on not use it for long time and make points rusty and points are unable to connect with battery terminals.
Posted on Apr 10, 2011
My rebel xsi won't turn on. there is nothing. I used it yesterday and it was fine. I changed the battery and still nothing! HELP!
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
Aug 09, 2012 | Canon EOS Rebel XSi Digital Camera
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
When I turn the power on the lens extends out of the camera and the power on light immediately goes off. The lens stays extended. no photo can be taken. This is a SonyDSC-P73 camera.
The only time that happens with mine is when I am low/out of battery power. I usually have to replace the batteries (even if the lens is still out) and then it works fine. Find it happens more often with rechargeable batteries because they still have a bit of power left, where regular batteries have nothing left after they 'die'.
Mar 05, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
With fully charged battery 5D has power but will not take shots
This sounds like your release switch is faulty. I have repaired several of these 5D cameras with similar strange symptoms. Basically what happens is the first switch on you release assembly cracks and breaks thus making continuous contact. When this happens it basically locks up your camera. The solution is to replace the release switch assembly. The repair should not cost you more than $150.
Hope this helps.
Wes Kauffman
Jan 05, 2009 | Canon EOS-5D 12.8 Megapixel SLR Digital...
Will not power up
you've probably misplaced batteries or used different kind of batteris. try take it to a service point.
Aug 10, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Power does not come on. Light below memory stick slot blinks. Battery is not problem. Nothing else but that light will come on. The camera will not come on. I have tried various batteries and even the
Your laptap MS card reader might not be properly installed. It might have been uninstalled or corrupted, which can always happen. Try going to your control panel, device manager, then uninstall the device, and install it again. It shoudl work this time. Good luck.
Jun 20, 2008 | Sony Handycam DCR-SR200 Camcorder
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
No Power
most likely you have blown the battery probally putting too many volts into the camera and you might need to get a new battery. i had the same proble with my portabe dvd player and a new battery worked.
Mar 03, 2008 | JVC Cybercam GR-DX95 Mini DV Digital...
Nikon COOLPIX L20 Digital Camera Logo
53 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
