Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
Timer with red switch on side. The switch is marked T at one end and ON at the other. Thereis a 24 hour dial. How do I set a light to go off at a certain time.
Open following link for instructions how to set timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Posted on Oct 06, 2011
Hi I have got an EDAPT timer but no Manual. Not sure how to set it up. Could you please help?
EDAPT timer is 24-hour analog timer with segments located around timer dial and a slide switch located on side. Appears to be mains 240V timer.
http://www.thewarehouse.co.nz/red/catalog/product/Edapt-24-Hour-Timer-Analogue?SKU=767408
Instructions for analog timers appear on following link.
Aug 24, 2011 | Hardware & Accessories
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Plug timer into wall.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I have basic timer # 15417. No instructions came with it and I don't know how to set it..
GE 15417 is electro-mechanical plug-in timer
GE 15417 GE15119 GE15131 are combined in one instruction sheet:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
1) Rotate dial until current time lines up with stationary black triangle located in center.
2) Segments around outer dial divide 24-hour day into 48 half-hours. Lift segments for times you want lights to be OFF. Segments down for times you want lights ON.
3) Slide-switch on side of timer is manual override. To use timer function, set switch to 'Timer ON'
4) Plug light into timer, plug timer into wall.
5) Maximum load is usually around 500Watts >> check markings on timer for exact load capability.
Nov 18, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Intermatic ej351, i ned the instructions for resetting the timer. to turn it on at 630pm and off at 100am pleae
1) Use this procedure to automatically program, letting switch timer "record" ON/OFF activities over 24-hour period.
-Move control lever to OFF-CLEAR for about
20 seconds. Red indicator light goes off and previous
time settings are cleared.
-Move control lever to ON position. Red indicator
light starts flashing.
-At 6:30pm, manually press dial 'on' >>> then at 1:00am manually press dial 'off'
-At the end of 24-hour period, switch timer is programmed and Red indicator light will stay ON, indicating
switch timer is in AUTOMATIC mode.
2) Or you can manually program times using instructions from page 1 of manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Sep 19, 2010 | Hardware & Accessories
There is also a way of setting it by simply turning the light on and off at the desired time. Can yu help?
Manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The manual says:
"To automatically program, letting the switch
timer "record" your ON/OFF activities over a 24-hour period,
storing them as programmed settings:
20 seconds. The red indicator light will go off and any previous
light will start flashing.
Press the dial as an ON/OFF switch to turn lights ON and OFF
at the ON and OFF times you desire for the first 24 hours.
At the end of the 24-hour period, the switch timer will be programmed
and the Red indicator light will stay ON, indicating
that the switch timer is in AUTOMATIC mode."
Sep 17, 2010 | Intermatic Programmable 24 Wall Switch...
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
Programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
48 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Freddy
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
