Question about Jaguar Heating & Cooling
Hi my jaguar x type 2002 2.5 v6 has been regassed and no leaks found but its not cooling the air I have checked all fuses and relays and they are all ok is there anything else I could try myself
    Scholar:
  • 133 Answers
Just two things without equipment. (That I know of). Is the clutch pulled in and the compressor running? If so, is the larger line coming from it cold? DON'T touch the small one! It could be very hot. If the clutch is not engaged, follow the larger tube from the compressor toward the fire wall. There is a low pressure safety switch that could be bad and can easily be by passed to check. Unplug the two wire connector and jumper those two wires. Be sure the AC control is set to "MAX COOL" and your thermostat is as low as it will go. Let me know if the clutch is engaged or the compressor running. You could have a 12 volt compressor with no clutch. They are out there. Roger
Posted on Apr 10, 2011
Where do you put gas for air conditioner for s-type jaguar
Hi Barry, If you look carefully at the two AC pipes you will see two plastic valve covers (similar to valve caps on tyres, but larger). One is high pressure and the other low. When regassing the engine should be running ith the AC turned on. Regards John
May 05, 2014 | 2000 Jaguar S-Type
Location of the fuel pump relay on a 2002 jaguar xtype 3.0
No FPR fitted.
Works via fuel pump module.
Module powered from fuse 81 on diagram of fascia fuse box. This fuse gets its feed from the ignition relay.
dae5bb3c-0053-4ad2-8bb0-945413126f57.jpg a02d94cb-80b8-4f3a-8548-93247d9e0aa9.jpg
Mar 14, 2014 | 2002 Jaguar X-TYPE 3.0L
Electric fan not working
engine fuse box = fuse 13 boot fuse box = relay R7 check this out
Hope this helps
Apr 24, 2010 | 2005 Jaguar S-Type
Hi,iv got 2002 jaguar s type r last week it started leaking engine cooling liquid from back of engine above gearbox i tried evrything to see where it was coming from but couldnt find out so i assumed it...
yes you got it in one,, its an air lock stoping the water going round the heater, you need to blead the air out rad seal wont block up the heater,,,,iv used it many times,,,my old truck ran with it in for years!
look for a bleed scew on a water pipe and open it with the motor running let water ran out till no air is in it, top up header tank as well
Nov 21, 2009 | 2002 Jaguar S-Type
My heater fan is not working on my jaguar x tyoe fuse ok what could it be
Check the fan motor runs ok if power directly applied to it,
if OK:-
check operation/replace blower motor control relay (if fitted),
check fan speed control resistor pack- usually mounted in heater air ducting.
Nov 11, 2009 | 2002 Jaguar X-Type
2002 Jaguar x-type air conditioning does not cool
hi, you will probably find that you need to get it re gassed this can be done at most garages they will charge a fee for doing this but it will solve your problem
Let me know how you get on or if you need further assistance ok
Nov 09, 2009 | 2002 Jaguar X-Type
Interior lights
if it was me and the fuse is ok then I would check the bulb to see if it was blown
Feb 21, 2009 | 2002 Jaguar S-Type
Heating & Cooling Logo
135 people viewed this question
Top Jaguar Heating & Cooling Experts
rdjagger
 Mikey
Mikey
ray gallant
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
