Question about Char-Broil CharBroil 4637318 Grill
Need to find a replacement part for girl. Tube Burner 4068212
    Scholar:
  • 106 Answers
Found my replacement at Lowes hardware
Posted on Apr 13, 2010
The top left front burner will not ignite. The igniter is sparking, but does not ignite burner. You can smell the gas. The burner will ignite with a match.
Hello
This sounds like the tube that runs from the burner to the ignitor is clogged. If you raise the top of the stove, look for that tube, take it out and run it under some hot water to remove the residue buildup. Replace the tube and try it again. My thought is that is the trouble,
Let me know how you make out, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Ovens
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Jan 15, 2011 | Weber Genesis Silver A Grill
0ne burner won't ignite, there is no spark from the igniter on the burner. How do you diassemble a burner unit?
Hello- These burners can be difficult to disassemble. I would first try an brush the ignitor, electrode, with a wire brush if it is blackened just be careful not to crack the ceramic. Also, make sure that the burner cap is on correctly, it will not spark if the burner cap is not positioned correctly. In order to remove the burner you have to remove the Ventrui tube, this is the bronze nut with the tube attached that is in the center of the burner. You will need a 20MM socket. If you can get the venturi out the burner will pull off. I believe on this one you have to take off both burners in order to remove that section of the cooktop. Be very careful no to force the nut because if it starts to turn but is not actually loosening then you are turning the orifice holder underneath and can crimp or crack the gas supply tube to that burner. The problem with these is that they often do not come out and have to be drilled off and then replaced along with the orifice holder that it screws into under the cooktop. Now, if the problem is occurring on one of the burners that has the extra low simmer (the ones that you can set to come on and off at an interval) then you will probably need a Potentiometer kit which replaces the switches and the spark module. Unfortunately it will probably be best to have a Tech out who is familiar with Thermadors and their particular issues. Sorry
Sep 27, 2010 | Thermador PC366BS Stainless Steel Gas...
Replace burner tube from GE stove
two screws on the back wall usually one or two on the front lip also remove the ignitor from the burner tube before you take off the burner tube be very careful not to break the ends on the ignitor or you will have to replace the ignitor as well hope this helps
p.s. look inside your oven with a light this is a very easy fix and makesure u unplug the power before working on your appliance
Aug 11, 2010 | GE Ovens
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Won't start
Try clearing the venturri tube. Sometimes spiders will build webs inside the venturri tube, restricting the flow of propane to the burner. If the venturri tube is clear, try cleaning the individual ports on the burner itself. Grease, food debris, and rust can clog the burner ports restricting the flame from coming up. If neither of these work, you most likely have a faulty regulator and need to purchase a replacement regulator.
Hope this helps!
-Ben
Tanks 2 You Propane
propanetanks2you.com
Mar 30, 2010 | Weber Baby Q Grill
I need a new gas feeder tube to the right front
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43634&diagram_id=762419#d762419
Copy and paste this link.
They have your parts in stock according to their inventory.
Jan 16, 2010 | Cooktops
I have a problem with a huffy 12 in. girls dora the
Sounds like the valve stem you may need a tube if you bought it new or recently new take it back??Hope this helps?
Oct 11, 2009 | Huffy 10 In. Girls Dora The Explorer...
Burner Welds
You have your burners misaligned with the tubes. Re-align the burners and the welds will hold up fine.
SuperTech1
Mar 26, 2008 | Pitco Frialator SG14 Deep Fryer
Char-Broil CharBroil 4637318 Grill Logo
53 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
