Pioneer dvd xv-dv33 - Error message (dvd3.3 error) appears after switching to dvd mode, then power shuts down.
  • Anonymous Nov 08, 2008
    I had experience the same this morning.
    With a music cd, each time I was trying start the player, the DVD3.3 error appeared.
    After disconnect the power supply cable and wait a couple or minutes, the error disappeared. I think they are the capacitors in the power supply, because I can hear noise in the speakers with the volume at very low level.
techman
  • 3130 Answers
SOURCE: pioneer ns-dv88
You willneed to have this unit serviced I'm afraid. You have a laser assy problem, or one of three servo circuits are not working. That would be the focus, tracking or the spindle motor circuits. Good Luck
Posted on Jun 19, 2007
SOURCE: Disk Error Message
when my mp4 player says disk error i hook it up to the computer to try reformatting it, but when i hook it up it does not recognize or show my mp4 player is hooked up. What is my problem and how do i fix it?
Posted on Jan 25, 2008
SOURCE: pioneer XV-DV99 high definition DVD/Rewriter
vrea si eu o mufa de alimentare la pioner dv99 dac orct pe el cata_micutu90 ai mufa b
Posted on Jul 27, 2008
  • 99 Answers
SOURCE: hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Posted on Nov 24, 2008
techjuli
  • 157 Answers
SOURCE: How to multi region my Pioneer XV-DV55
Most have "hack codes" but yours is in a select group of a few that simply cant be done with a couple pushes of a button.
As far as I am aware the only way to get thesemachines to play Region 1 discs is to have them chipped. A variety of solutionsare available, and it needn't be expensive (typically £30 to £70) but youshould be aware that any internal modifications to your players wouldinvalidate the warranty. Have a look at the following web sites for moreinformation:http://www.techtronics.com/uk/shop/50-000-dvd.html
http://www.maxking.co.uk/dvdmod.htm
http://www.dvdchips.co.uk/
I know you were looking for a free solution you could do in a matter of seconds and sorry it didnt work out that way. Regardless, I hope I pointed you in the right direction and feel free to ask if you have any more question.
Happy Holidays,
TJ
Posted on Dec 15, 2008
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
while stad by bottan pressing oc error coming on display
Jan 19, 2013 | Pioneer Televison & Video
I have a pioneer vsx 07 11 and it says amplifier error
You see, the error message is coming from the power protection circuit which is constantly monitoring current being drawn from the receiver power supply. When the current exceeds the trip level it shuts down and give the error message.
power amplifiers has been shorted and the output transistors (one or more) have gone into breakdown and causing the excessive current drain. This will happen even though the speakers may not be connected to the amp outputs.
Jun 05, 2012 | Pioneer Audio Players & Recorders
I have a Pioneer DVR 531H and I get the HDD error message What's the solution Barry
I have a Pioneer DVR 530H and I get the HDD error message and freezes
What's the solution
Aug 20, 2010 | Pioneer DVR-530H-S DVD Player/HDD Recorder
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
No sound from front center and rear speakers on my xv-dv55
Hi
1st check your cables are inserted into the subwofer (which is the powersource)
however it sounds as though you have switched the player to mono mode to reset it try this
2. On your remote press the system button with the green ring around it 3. Then press the dts button (number 7) keep pressing it until the auto option appears (watch the little black display screen)
hope fully that should fix it
I am assuming that you no longer have the manual other wise you would have checked in there? But if you do and this does not work try read the first few pages on setting up the sound for your system.
Lou
Apr 05, 2010 | Pioneer DV-340 DVD Player
Pioneer XV-DV99 high definition DVD/Rewriter
Try one of these codes:
221, 222, 154, 160, 174, 180
Or use the Seach feature:
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Hope that fixed ya...
Geno
Mar 28, 2008 | Televison & Video
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
Televison & Video Logo
319 people viewed this question
Top Televison & Video Experts
Electro Med Services...
