Whenever i try to connect wifi, iget your AP is not respounding
  • 40 Answers
Make sure you enter correct network ID and password (if present). Also check if router is working.
Posted on Apr 10, 2011
Where do I find my SSID#
The SSID is the identifier for the wireless access point (AP) you are trying to connect to. If the AP is broadcasting, the SSID should appear in a list of available WiFi connections when you enable WiFi in proximity to the AP. The SSID is not necessarily a number, it can be ASCII text, such as "MyAP1234" or "Linksys". You click on the displayed SSID you want to connect to and if it is encrypted, you will be asked to put in the password or access code. Some AP/routers have the SSID and access codes printed on a label on the bottom of the router. Otherwise you have to get them from the provider of the WiFi access. Some AP's don't broadcast their SSID's and you have to get both items from the WiFi provider and use your phone's connect process to enter the SSID and access code.
Apr 25, 2015 | Kyocera Cell Phones
Whenever i activate my wi-fi in my S5263 then answer comes no wi-fi ap found
make sure your are near a active WIFI device and that device is not hidden and you know the password of the wifi device . try once your have all the above things you will be okay!!
Jun 14, 2011 | Cell Phones
Hi I'm trying to use my desktop pc with ASUS P5Q3 Deluxe Wifi AP @n motherboards onboard WLAN as an Access Point to my Nokia X3-02 phone for WLAN. Would be nice to use same internet connection through...
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect to your phone
hope this helps
May 10, 2011 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
Whenever i connect via wifi, it always says "authentication failed"
Yeah, they confirmed that they have some problem on some wifi authentication especially when your AP is configured to WPA-PSK (TKIP or AES).
you can only connect wifi with open, shared, WEP 64 and 128bit authentication and WPA/WPA2. Samsung still dont have any solution to this big issue. Been a lot lately to customer service in plaza sing, talked to the manager a lot with this problem,
still NO SOLUTION. You can't even have a full refund, no change model.
Jan 15, 2010 | Samsung Jet S8000 Cell Phone
I can't connect to the wifi even in taskbar it shows that wifi is connected and signal strength is also very good. mine is acer aspire 3680. please help. also tell how to install lan drivers.
Hi Dear. Verify DHCP or Manual IP configuration from AP/WIFI Router. Disconnect and Reconnect and follow IP configurations as mentioned in AP/WIFI Router.
Feb 26, 2009 | Intel D865GBF Motherboard
Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
Sep 26, 2008 | Sony Computers & Internet
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
