Question about Minn Kota Boating
I have a Minn Kota Edge 70, 24 volt bow mount trolling motor. It just randomly stops working. I have checked all connections and they seem good. It seems to stop working for a minute or two and then starts up again. Any advise would be appreciated.
  • 157 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Hello raventrans. I suggest you contact www.minnkotoamotors.com/index.asp and ask for est#406, Dave.
Posted on Oct 19, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
  • 8 Answers
SOURCE: how does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Posted on Sep 07, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
Hot plug connector
if everthing else is hooked up properly and the battery connections are tight i would suspect a loose connection in either the plug or the receptacle. anytime an electrical connection heats up it usually means there is a loose connection or too many amps running through it than what its designed for. remember trolling motors should not be run out of the water for more than 30 seconds as they use the water to cool the output shaft at the prop. good trolling.
May 30, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Lookinf for a manual for a minn kota model 55d
call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Broken plastic on minn kota steering cable
Hi!
Here's a schematic:
Edge 40
My guess is you need key# 80 (part# 2232360 cable drum pulley)
Good luck in your repair!
Mike
Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
I cant adjust foot tension on minn kota edge
Hi!
Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
Here's a schematic:
Edga 40
Best of luck!
Mike
Jun 06, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Boating Logo
42 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
