Question about Seagate (ST310005EXA101RK) 1 TB USB 20 Hard Drive
Seagate (ST310005EXA101RK) 1 TB USB 20 Hard Drive i have an error message error 55. registry problem. i plug into my laptop all is fine ..please help..wont run on desktop. has been running fine on desktop last 2 months.
  • Seagate Master
  • 27,725 Answers
If this error is a registry problem
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don
Posted on Apr 10, 2011
ST310005EXA101RK
I would contact Microsoft about that. Hopefully the original drive has not been erased of formatted.
May 22, 2014 | Seagate (ST310005EXA101RK) 1 TB USB 20...
How to use (ie download programs)
please HELP. What do I do to download - usb 2.0 plug and play seagate expansion portable drive
Sep 18, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
When i installed my Seagate 1 TB USB 20 Hard Drive to my computer it worked. But when i plug it in to my other computer nothing shows or comes up. Why is that?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Aug 28, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
My drive has been working perfectly with my PC for a couple of years, it's about 75% full. Last night I attached it to a different laptop and it worked fine there. When I reconnected to the original PC...
Try to scan your Had Drive with updated anti virus it may attacked by a virus. Connect it again where the hard drive is working fine. I have some clarification if you disconnect it properly in the computer where you have the time you use it. Because if you disconnect it in your PC without proper procedure it may possible cause of corrupting you files inside you hard drive or internal damage to your hard drive.
Jul 19, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
The small USB on my seegate 1TB Harddrive has fallen into the casing. (So I have nothing to plug the USB lead into) It is only 3 months old and I have very important documents on it I need to copy off it.
Well, this will probably void any warranty you have on it, but you can simply remove the plastic casing. At the end of the day it's just a hard drive with a small component with a USB port. When the case is off you can plug it in normally, just be careful that you don't sit the hard drive or components down on anything that will conduct electricity.
Jun 24, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
My laptop(running Vista) allows me to see a folder on my Seagate external drive but will not allow me to see the folder contents.
Is that the System Volume Information folder? If it is, you can't see the content of this folder as it's a system folder and it's related to the restore points your PC is creating for that hard drive.
Else, it may be that whoever created the folder has locked it so you cant open it without a password.
Jan 19, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
My drive just stop working,how can i get back all the data?
Yes...you can buy an adapter at office max or best buy, or circuit city and stick the hard drive in it for @ 30 bucks.
Jan 07, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Seagate (ST310005EXA101RK) 1 TB USB 20 Hard Drive Logo
212 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
