How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
  • 40 Answers
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
Posted on Apr 10, 2011
Connecting Seagate Backup Plus Desktop drive (STCA3000101) to Belkin N750 wireless router.
Usually you don't need to setup any additional settings or creating new users on the Belkin router to access an USB HDD attached to it, if you used the Belkin Router Manager to set it up.
The Seagate drive you are using have it's own power supply, so that should not be a problem. Also the accepted formats are FAT16, FAT32 and NTFS formatted HDD.
You can try to set it up again using the manager. This is the user manual for your router, if it helps:
http://www.belkin.com/networking/manual/MAN_F9K1103_8820-00778_RevA01_N750.pdf
If you still can't get it working, let me know and we will try to find another solution.
Jan 05, 2014 | Belkin (F5D8231-4) Wireless Router...
Tip
How to Map the Storage Drive Connected to F5D8235/8635 N+ Wireless Router?
Important Note: Pleasemake Sure that you are able to Ping the Router's IP address, on the computer onwhich you want to map the Drive.
Installing Storage Manager Utility toMap the Storage Drive:
Run the Installation Disk on the entire computer connectedto the Network, which will install Storage manager utility.
This Storage manager utility will automatically map thedrive (e.g.: Z drive) and which can be found in My Computer. Double click onthe drive created in My Computer (e.g.: Z drive) to access the data, which isstored in your Hard Drive, connected to the router.
Mapping the Drive Manually:
If you do not want to Install Storage Manager then you cango for Manual Mapping.
To get the Drivemapped and listed in the My Computer then follow the steps given below.
· Click Start and Right Click My Computer
· Select 'Map Network Drive'
vargheseacer_4.jpg·
By Default, Select Z: in Drive box.
· In Folder box, type in ' (IP address of therouter)(Drive name)
For e.g. 92.168.2.1DriveName
Note: Connect the StorageDrive directly to the Computer to modify or check the name of the Drive
· Click Finish
Double Click on the drive to access the data, which isstored in your Hard Drive, connected to the router.
Or
You can Access theDrive Files Directly without Mapping the Drive:
Click Start and Go to 'Run', Type in " (followed by IPAddress of the router)".
E.g.
\\192.168.2.1
This will take you to the Window where you can find the nameof your drive. Double Click on it to access the data, which is stored in yourHard Drive, connected to the router.
Note: The Router Does notassign IP Address to the Storage Device
on Dec 12, 2010 | Belkin F5D8236-4 Router
Need documentation on how to attach WD PassPort HDD to Belkin N+ router using usb port on router ... to be accessed by Windows 7
Gather and connect all necessary connecting cables. You need an Ethernet cable to go from the box linking the hard drive to your wireless router in one of the open ports on the back of your wireless router, and a USB cord connecting your external drive to the storage link box (unless you are using a flash memory device or stick drive).Power up the devices. Make sure your Internet connection Is working and that the storage device is working properly.Insert the Setup CD into your computer. Follow the instructions and install any necessary utilities for the specific type of external drive you are using. Configure the storage link. During setup you should have been given the option to secure the device with a login name and password. Open the device and log in. Make any changes you want to on the storage device, but if you aren't sure what specific changes you want to make to the default settings, leave the default settings alone to avoid creating problems.
Mar 13, 2010 | Computers & Internet
Lost ability to see usb storage through wifi.
try disabling the firewall in the computer. check if the USB light is on in the router. if its on.. then update the firmware of the router.
Feb 10, 2010 | Computers & Internet
WD My Book 1TB not recognised by belkin modem router USB storage
If I understand correctly ... You have not connected the drive to a computer.
If I am not mistaken the WD My Book has preinstalled backup software installed on it. It very well might also have a power down built as part of that programming. Try attaching it to a computer to verify this.
Assuming the backup software needs blank drive to work correctly I would first access the drive select all and delete anything you find (if you know how to unhide hidden files do that before you select and delete all) ... As a 2nd option I would just reformat the drive.
Hope that helps....
May 31, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Hi
i am fairly certain The WD my book external hard drive needs to have the correct software to be able to use and because routers dont have a CD drive i dont think you will be able to do it.
Apr 27, 2009 | Belkin N1 Vision Wireless Router
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
This is not as complicated as it may sound. You don't need the manager. Bring up the "run" window (XP - Start - Run / Vista Alt-R). Enter the following address [\\192.168.2.1] press enter. The drive will show up. Right click on it and select Map Network Drive. You can then uninstall the useless program from Belkin.
Jan 20, 2009 | Belkin N1 Vision Router
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
