Question about Bowflex Treadclimber TC5300
My bowflex treadclimber treadle friction block is rubbing and shaving the plastic. It is making a rubbing noise
3 Suggested Answers
  • 10865 Answers
SOURCE: Bowlfex TreadClimber treadles on my
Hello crd.... Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Joe
For future reference, you can call bowflex directly by telephoning (800) 667-1689.
Thanks for choosing Fixya!
Posted on Feb 19, 2011
guru_fixya
  • 944 Answers
This is a common problem with this
Bowlfex TreadClimber.When it gets old the belt also get very old and gets over stretched.This results in sound.Call bowflex directly and ask Call (800) 667-1689. They probably have service centers located near you.Ask them for new belt and if you have warranty you can claim it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 20, 2011
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
Treadles only go uo and down about 3 inches. Hard to move them
These are fairly complex machines...call foe service 877-805-1030
Jan 03, 2014 | Bowflex TreadClimber TC5000
The treadles on my treadclimber are not rising and falling evenly. The treadle on the right seems ok, but the left treadle stays significantly lower. I have tried adjusting the dial to a lower number on...
Please RUN the software calibration for easy diagnostic and fix it.
go under the HOOD motor follow the steps, or read your owner manual /download from www. fitness.manualsonline.com
GOD BLESS YOU
Dec 02, 2013 | Bowflex Treadclimber
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
One treadle is rubbung on the upright
The rear bolts are loose. I had the same problem and found the four 3/8" bolts loose. You need to take the rear side covers off first then the rear cover to get to the bolts.
May 15, 2010 | Exercise & Fitness
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Bowflex Treadclimber rubs against housing.
Mar 05, 2009 | Bowflex Treadclimber TC5300
Bowflex Treadclimber TC5300 Logo
183 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Bill Boyd
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
