Question about Kidde Kiddie Ac Wire-in Smoke Alarm I12020
Rental mgmt company just installed Kidd 112020/40/80 (don't know which one. It does the same thing the previous smoke alarm did - wakes me up in the middle of the night! It chirps every hour, every 30 seconds or so for about 8 times. Only thing I can figure out by reading on the net is that I turn my heat down at night. This is ridiculous if I am to spend my money on keeping the heat on to make the smoke alarm stop beeping at night. Please help.
  • Kidde Master
  • 17,328 Answers
They only chirp for two reasons:
1. The sensor is past its useful life and needs replaced
2. There is a power issue with the battery. Even the ones that are hardwired into the electrical system need a battery.
Posted on Jun 23, 2017
frcs68
  • 1605 Answers
SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
Posted on Dec 02, 2008
  • 103 Answers
SOURCE: Alarm Keeps beeping every 30 sec
change your battery cos its ded lol
Posted on Apr 06, 2009
szanti
  • 36 Answers
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Posted on Sep 28, 2009
szanti
  • 36 Answers
SOURCE: KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
  • 905 Answers
SOURCE: My alarms are chirping every 30 seconds or so. I
Depending on manufacturers and such, the catalyst detector element itself may need to be replaced occasionally. Usually cheaper and faster to just get another detector.
Posted on Nov 02, 2009
Please advise the approx cost for installation of smoke alarm for 2 bedroom unit. Thank you
If you don't mind changing batteries every 6-12 months during the year then you can pick up these smoke alarms from any hardware or even discount store. The also come in blister packs (2 to 6 or more for value packs) Most will screw mount to attach to wall. You can also use self stick foam tape to 'stick it' anywhere. Try to put them in a high spot on wall or ceiling depending on the surface (crumbly textured surface won't stick well. It will have to be mounted with a screw) The higher locations will give you quicker response time but It's harder to get at without a step ladder. Lower units have slower response time as the smoke has to collect and lower to the point where the alarm is.
*** Note; you will need to check your fire code requirements for placement of alarms. (though once this minimal requirement is met there is no reason you can't add more in other locations for added coverage; like a large walk in closet, baby's room, laundry room, etc.)
* Getting back to your question, I'm guessing you have the updated required powered alarms or need to have a "Powered" fire alarm. The newer homes (well last 20 years is new to me) have low voltage power lines running from room to room where the alarms are placed. If you required to install this type of system then depending on the ceiling access (crawl space, lowered ceiling, etc.) and the need to run the wires "hidden" behind wall and ceiling will increase the installation time and labor costs. Electrician or authorized fire alarm technician will be needed. They should check your fire alarm requirements for you local, indicate locations for alarms, run wires, install and test. Check with several companies in your area and get several quotes. Check with Better Business Bureau for rating or complaints.
* With Smart ware being all the rage. It may be possible to use these "smart devices" to alert you to other situations besides just fire hazards. Break in, baby monitor, door ringer monitor, water (flooding), Carbon Monoxide, etc. But the alarm guy should be able to give you more options. Though I's still up to you how much you want to spend.
* Final; You check what the fire codes require. If they called you first then suspect a scam or a sales pitch to get you to buy something you don't require. You can always go with the 'stick on' alarms if that is allowed for your area. Call the fire Dept in your area. Those are the 'good guys' that want to keep you safe.
Aloha, ukeboy57
Jun 06, 2018 | Home
Smoke not going up chimney
damper closed in chimney or blocked chimney
Jan 04, 2017 | Cars & Trucks
What kind of alarm equipment does the company provide?
Depending on what ur using it for .check out swann or logitech website
Oct 15, 2014 | Home Security
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
How to set alarm on samsung tracfone
If it's the T105G (same one I have), here's how:
  1. Select "Menu"
  2. Select "Tools"
  3. Select "Alarms"
  4. Make sure "Wake-Up Alarm" (1) is highlighted and press "Options"
  5. Press "Select"
  6. Press the ">" key to turn alarm on
  7. Pres the "v" key to highlight "Alarm Time"
  8. Enter the alarm time with the keypad
  9. Press "Save"
I don't know how many other Samsung models TracFone sells. If yours isn't the same one and doesn't work the same way, you can check TracFone's website for details.
Aug 16, 2011 | Computers & Internet
Dont know how to set time or alarm
Press and hold the Set Wake button and the press either the fwd or rev button until the desired Wake time is reached. Release the buttons to return to the current time display. To display the wake time, press and release the Set Wake button. To turn off the alarm, press and hold Wake Mode until the alarm icon disappears. (This button lets you choose Wake to Music, Wake to Alarm or Off.)
The owner's manual is available here: http://support.radioshack.com/support_audio/37571.htm .
I hope this helps.
Mar 11, 2011 | RCA RP3711 Clock Radio
I left my gps on a rental car. There is a way to track it and get it back?
Not unless you set something up previous to the loss, but I don't think that TomTom has this feature. I would personally call the rental company and explain to them.
Oct 13, 2010 | Tomtom GPS
None
I would Recommend that you update the Alarm panel your alarm company. Because then they would be able to show and give you information on how to use the new alarm, instead of having an alarm panel that is out of date and no longer has a company backing it. Good Luck!
Jun 26, 2009 | Kitchen Appliances - Others
Cannot shut the alarm function off all together.
Disable the alarm permanently 1. Press CANCEL button. 2. The WAKE indicator will be flashing. 3. Press WAKE MODE button within 3 sec- onds to deactivate the alarm function per- manently.
Mar 23, 2009 | GE 7-4837 Clock Radio
Kidde Kiddie Ac Wire-in Smoke Alarm I12020 Logo
111 people viewed this question
Top Kidde Home Experts
Paul Bade
Are you a Kidde Home Expert? Answer questions, earn points and help others
