Question about Microwave Ovens
REGESA TURBO C2 20P L - Microwave Ovens
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Panasonic rattling noise
magnetron going bad, or fan blade
Apr 22, 2014 | Panasonic NN-S251 Microwave Oven
My panasonic microwave is locked
I cant open it please brother Touch English-locked microwave instructions
Jun 28, 2013 | Microwave Ovens
My microwave fan turns on like turbo on its own
You probably have a bad door switch, or there is a possibility the keypad control board is the issue.
Apr 19, 2012 | Kenmore Microwave Ovens
Microwave Manual
You can get the manual for this model here:
www.chsinteractive.co.uk
Sep 27, 2009 | Panasonic Microwave Ovens
Turbo vent won't turn off
This is usually caused by a shorted hood thermostat or a shorted triac on the control panel circuit board.
The hood thermostat is usually located on the floor of the microwave chassis behind the control panel. It should read "open" or "infinity" on a continuity or multimeter resistance test.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
If the hood thermostat is bad, You can order Samsung parts here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 03, 2008 | Samsung SMH7178STD Microwave Oven
Panasonic Dimension 4 Turbo Bake Microwave oven. Everything works except the microwave element. Why?
Your Magnatron is most likely to have failed, its an expensive part and on a turbo 4 could be 2M236-M42. Unfortunatly this appears to fail due to reduced air flow. So if you do replace it I would clean the rear grills completely to increase the airflow within the oven.
Apr 14, 2008 | Microwave Ovens
Samsung overcounter microwave-light and fan problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 04, 2008 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
494 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
