Question about Cub Cadet Garden
I have no spark on my cub cadet 2182 model o have replaced the coil and plugs what else should I b looking for
  • 7 Answers
SOURCE: I am looking for a diagram on how to replace both
Go to www.ihregistry.com/manuals/op.php
There you'll manuals on everything Cub Cadet.
Posted on Jun 10, 2009
  • 148 Answers
SOURCE: Cub Cadet 2145 doesn't have a spark
Great!
Posted on Jul 22, 2009
  • 53 Answers
SOURCE: I have a Cub Cadet 782 mower and I can't get any
the air gap mast be checked make sure you have the right adjustment on the magneto.
Posted on Sep 08, 2009
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
SOURCE: my cub cadet mower LT1042 will not start. It acts
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
Posted on Apr 30, 2010
Where can I get a repair manual for my 2182 Cub Cadet lawn tractor
I would imagine that the Cub Cadet web page would be a good place to start - maybe "parts"?
Aug 03, 2017 | Cub Cadet Garden
Cub cadet 2166 16 hp kohler command. no spark. replaced coil still no spark
Check the ground wire to yhe coil it may not be releasing so the coil can send spark to the plug
Jul 20, 2017 | Cub Cadet Garden
I need to know the location of the spark plug on my Cub Cadet GT 2550. I need to replace it.
They are on each cylinder head. There is a wire from the coil to each spark plug. Remove the wire and you'll see the spark plug
Mar 29, 2017 | Cub Cadet Garden
I have a cub cadet model 800 the engine turns over but have no spark to the plug
check coil for short that model shorted a lot causeing no fire check the wires on the coil look for breaks or bare spots
Jul 06, 2014 | Cub Cadet Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
No spark cub cadet 933E changed plug still no spark motor cranks fine
you may want to check the coil. under the coil there is a wire (kill wire) unplug it. try to start it, if it starts you have a bad wire somewhere. if it don't the coil is bad and needs to be replaced.
Nov 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
93 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
