Question about Verbatim SureFire Portable Hard Drive
I am a mac user and i use my Verbatim SureFire 500GB hard drive many times a day but recently is has stopped working. When i plug my hard drive into my mac it makes a beeping noise and then my mac doesn't even pick it up. I have never had this problem before and i hope i haven't lost any of my data. I have tried using the different connections such as the firewire and the usb connection but it doesn't seem to make a difference. I have also tried plugging it into my other macs but none of them pick my hard drive up. The last time i used my hard drive before it stopped working was on my macbook, I shut down my mac and then when i rebooted it, this is what it did. I have tried doing research on how to fix it but nothing seems to help. I don't know what to do anymore and if you could please help me that would be great. Thanks, Corey
  • 23 Answers
SOURCE: Trying to use a brand new Verbatim usb 500GB portable hard drive
For WindowsXP:
Goto Start> Control Panel>
Select Hardware Tab > Divice Manager
Select the + on Disk drives, and see if you see your USB Verbatim drive listed (if so good, close all thoes windows and goto the next steps) If not stop here.
From the Contorl Panel> Administratinve Tools> Computer mangement>
Under Stoage select Disk Management on the left panel
Look in the Right panel and single click your USB drive in the "Volume" colume.
Know look at the lower panel and make sure the drive states that it is "Online", look at the "Health" Status. And;
Make sure it has been "Partitioned" in the Layout colume. If not right mouse click the drive letter and select "Mark Potiton as Active".
Right mouse click on the USB drive in the Volume colume> select "Change Drive Letter and Paths"
If there is on drive letter assing to it select the Add button, if one is there, select the Change button and assign one to it or change it to a drive letter that is beyound the number of drives you have.
In other works if you have drives C:, D: and E: before you add the USB drive, make it the H: drive.
Exit out.
Now check your drive files.
Posted on Feb 14, 2009
SOURCE: external hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Posted on Apr 10, 2009
  • 739 Answers
SOURCE: My mac cant see my minimax 500GB, it powers on and
The above answer is wrong. All MiniMax drive are formatted for Macs out of the box (that why they are shaped exactly the same as a mac Mini).
Try connecting with a USB lead to see if that works.
These units are generally very good (i've installed about a dozen in the last year) but I have known some be DOA (I've only had one). Do other externals work in your FW port? If they do, plug them into one of the other ports on the MiniMax and see if they still work.
There is always a chance that your FW port is faulty - they have been known to need resetting (you'll have to google that as I can't remember the exact procedure - I think a quick way is to disconnect everything from the mac - yes everything! and leave the mac sitting naked and forlorn for about 20 minutes, then reconnect everything including your minimax and power up the mac. With luck it should come on and mount. Let us know what happens.
Posted on Jul 26, 2009
brukau747
  • 51 Answers
SOURCE: My Verbatim suddenly stopped working on my Mac OS
It sounds like your hard drive is damaged. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. It could also be just a mechanical failure. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Posted on Aug 31, 2009
  • 10406 Answers
SOURCE: Hello, my external harddrive (Verbatim, 500GB
> the HDD makes a clicking sound.
That's a very bad sign. :-(
> find a way to rescue the [files]
Search online for a professional "data recovery service". For a significant fee,
they can repair your disk-drive, just long-enough to copy your files onto a brand-new disk-drive.
Posted on Nov 04, 2010
Why wont windows recognize my verbatim 500gb serial no JB0094011152
Go into Device Manager and if it doesn't appear there click "scan for hardware changes". If that doesn't work, makes sure you have plug and play enabled. Always use the safely remove hardware option when unplugging it.
Jul 11, 2016 | Verbatim 500GB USB Desktop 500 GB Hard...
My mobile gt s5302 drow patan is five time worng then mobail user neme and pasword
1. Switch Off Your Phone
2. Press and hold Home Button + Volume Up + power on button
3.You will get four options and Select Wipe Data/ Factory Reset Option using Volume Key . Then Confirm by Select Yes Delete All User Data. Using Volume Down Key and Confirm it.
4 REBOOT NOW
May 29, 2014 | DURAGADGET Protective Case With Soft...
Verbatim hard drive
Hard drives are fragile, and if they fall sometimes you get lucky and other times no. The only solution is to bring it to a computer store in hopes they can extract your files.
Mar 05, 2012 | Verbatim External, USB 2.0, 500GB...
I can't get the Verbatim Clon to work on my Mac. I don't really know what I'm doing wrong. The user guide says I need to set up the Nero BACKITUP software and that I do this by double clicking on the...
The Nero Backitup Software is not currently supported on Mac OS X.The setupx file you were trying to use was probably a .exe file which is windows only, .dmg is for Mac OS X. If you can view the drive when plugged into your computer than you can use it to manually backup, or you could find a backup software that is mac compatible. Seeing also that the drive came with a .exe, it might not be formatted properly, which could explain if it doesn't show up at all on your desktop or in Finder. To use the drive effectively you would need to reformat the drive to a Mac compatible format then simply use whatever backup software you find to fully take advantage of this advice.
Or you could return it and find a drive that is currently supported by OS X.
Mar 12, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim Model #USBPRO500 Shows up on list of
use the source (pc/Mac) that created the data to remove it.
you will need to re-format to get it to work on the machine you are currently trying to use.
(personally I always remove all partitions and format to "fat" (remove factory) this will make the drive work on Mac as well as pc)
hope this helps
Dec 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Hello, my external harddrive (Verbatim, 500GB USB/FW800) stopped working. When connected the blue LED lights up. After 3 sec it goes into flash mode. The HHD makes a clicking sound. The MAC Hard disc...
Nov 03, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I am trying to write files to a terabyte verbatim portable hard drive, but it saids the drive can not be modified. How do I write to the verbatim hard drive on my mac?
Most verbatim drives are formatted to by default to NTFS which is a windows file system. NTFS can be read and copied from on Mac but not written to.
You will need to offload the data to one of your computers and reformat it with the mac.
Apple, Utilities, Disk Utility.
Once formatted for Mac you will be able to read and write to the drive but you will need to add macdisk to the windows PC to allow it to read and write to a Mac formatted disk.
I more information on my FAQ about recovering data from Mac drives on PC
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Mar 22, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Attached my SureFire SX500 portable hard drive (by
Sounds like you might have to initialize the hard drive. Go to the left on that hard drive (where it says Disk 1 or 2, etc) and right click. It should give you the option to initialize. From here you should be able to format, etc.
Good Luck,
NOLA Tech
Jan 31, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
External hard drive doesn't respond
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim SureFire Portable Hard Drive Logo
76 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Computer Links
Marcin
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
