Question about Whirlpool Washing Machines
I have a Whirlpool Duet front load washer model DHW 9300. I am getting error code dL and f when I try to start it and it will not start.
    Brigadier General:
  • 6,277 Answers
'dl' stands for Door Lock + Fault . There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Apr 11, 2011
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Duet front load washer door will not lock. I
Sounds like you have a door lock failure due to the fault code you have or it could be a control brd failure. Sometimes if either fails it will blow the other aswell.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front load locks and i get a error code fL 11 and dL
u need to change the main board. DL is a door lock error code
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LIGHTS ON WON'T TURN ON DL CODE
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
see this fix
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
