Question about Toshiba 120GB 2½ inch 5400rpm 8Mb Cache SATA MK1237GSX 120 GB SATA Hard Drive
I am not sure if i got aToshiba HDD. It is an external leather hdd called Prestigio. Only a scan using HDDScan revealed 2 items labeled as TOSHIBA MK1237GSX-979UFAWAS. The problem is that i can no longer read the entire disk, just 2 partitions, one is 20 MB, and the other one is 1,08 GB. I tried everything but it seems the formerly secured partition won't appear. I must say that i no longer have any backup copy or cd related to the hdd. What can I do? Thanks! Mario
SparkGap
  • 363 Answers
SOURCE: Seagate drive partition
This is fairly straightforward using the Windows XP tools.
IMPORTANT, copy everything you want to keep from partition F otherwise it will be deleted. Drive G will not be affected.
  • Right click 'My Computer' >'Manage' then click disk Management.
  • Right click your drive F and 'Delete Partition'.
  • You now have 210GB unused space on the drive.
  • Right click the unused space and "Create Partition".
  • Specify the size of the new partition to your requirements or create more partitions until the free space runs out.
  • You can then right click and format the new partitions. 'Quick Format' is fine unless you have been experiencing disk problems.
To swap around drive letters in Disk Management:-
  • Right click the drives and 'change drive letters', to X, Y or Z or whatever
  • Now you can change the drive letters back to F, G, H or whatever order you want them in
I'm sure you get the idea, you just have to change the letters of the drives to unused letters to make a space in the sequence (not that any sequence really matters)
Good luck
Posted on Nov 08, 2007
SOURCE: HDD data recovery
i had a problem with my hdd that is set up is copying files but when it restarts an error message comes ie,press alt+ctrl+del to restart
Posted on Jul 07, 2008
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
lock123
  • 6831 Answers
SOURCE: Toshiba 1TB External HDD having connectivity problems
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
sodeep
  • 3267 Answers
SOURCE: iam not able to (copy to or delete from) any file
just plug in your hard drive to your laptop and write click properties and check disc automaticaly
if not type in cmd chkdsk driver leter eg: E: F: like this make sure to give space in between chkdsk and driver letter.
in other way restart you laptop it will check you disk errors.
Another option is
1. Right click on I drive and select Properties
2. Click on the Security tab
3. Click Advanced
4. Within the advanced window select your administrator account and choose to apply onto "This folder, subfolders, and files" click ok
5. Then check the box at the bottom of this window "Replace permission entries on all child objects with entries shown here......"
Finally
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Posted on Nov 17, 2010
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Toshiba MK6025GAS HDD (External) not recognized
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
http://www.ebay.com.au/itm/280406610810?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
$2.37 + $2.61 postage worldwide
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
$10.65 free postage
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Nov 29, 2011 | Toshiba (MK6025GAS) 60 GB Hard Drive
I need free Information for my prob for toshiba estudio 200L. gives code F120.
Your HDD is having issues. First try to rebuild the databases by holding 0 and 8 while turning on the copier, when the machine comes ready key in 684 then reboot the machine. If this doesn't work you can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 15, 2011 | Toshiba Office Equipment & Supplies
My laptop uses toshiba mk3265gsx sata hdd.. but it's now broken because of motherboard problems. but my hdd is not broken.. yet i tried to make it to be an external hdd so i bought an enclosure.. now when...
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My toshiba hddr250 e03x fell down and not working . what to do?
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 25, 2010 | Toshiba Computers & Internet
I can't find my hard drive. Where is is?
1) Depends on whether you are using an external or internal Hard disk drive
2) If it is external HDD, ensure that the USB cable is plugged into the PC for auto connectivity
3) If it is an internal HDD, You have to unscrew your metal case, look for the 3.5 inches in rectangular dimension metal device screwed onto your CPU casing. Ensure that there is a physical cable connection between the HDD to the Motherboard. The cable that will direct you to the HDD from the Motherboard should either be the SATA (Small Flat headed Red cable) or the IDE cable (white flat 24 pin cable)
On the HDD brand label there should be a Capacity size in MB or GB or TB, Cylinders, Heads and ensure that the poswer supply is connected to the HDD if it is an IDE HDD
Jul 29, 2010 | Computers & Internet
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Toshiba Motherboard and Harddrive
No you can't replace the ata m/board but you can upgrade your hdd's up to 160gb in ATA
Dec 08, 2008 | Computers & Internet
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Toshiba 120GB 2½ inch 5400rpm 8Mb Cache SATA MK1237GSX 120 GB SATA Hard Drive Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
