Question about Hobart DGC504 Stainless Steel Kitchen Range
Will a hobart HCR42 3 phase 208 v work with 3 phase 240 v with a high leg
  • 37 Answers
It would not work right the elements are made for 208 not 240.the elements would run hot to much voltage.control transformer would be tapped for 208 and not 240 could have adverse effects on controls.motor would probably be fine most are made for 208-240.I would not do it.
Posted on Apr 22, 2011
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
Wiring a dimmer switch with 208vac, single pole
208 Volt 2-wire is generally achieved by pulling two hot wires off 3-phase 120/208 Wye or 208 Delta, or Highleg to center tap off high leg delta.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://waterheatertimer.org/images/3-phase-timer-diagram3-T104-208-240.jpg
Since each of these three phase systems also offers 120volt for lights, and a dimmer can be used for lights, then I wonder what you are using dimmer for?
208 volts.can be controlled by turning off one hot of the two hot wires.
Install dimmer on one of the hot wires, and see what happens.
Is the dimmer rated for 208 volts?
Add a comment and say what you discover.
Jan 03, 2013 | Generac HTSN400G 400Amp HTS 3ph 120/208V...
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I am working with a Dayton 2YU39. The name plates states that it has to be powered by 208 volt system. There's a 3-phase panel and a single-phase panel. The 3-pahse panel L1 to ground is 118 volts. L2 is a...
Here's what I think but you will have to check it out...
The fan motor in the 39 heater is a 120V fan there fore it cannot be hooked to the 240 which potentially could have the high (wild) leg as one of the fan legs...
The 240V 36 unit probably has a 240v fan motor....
Now if you were to make sure that the leg that fed the motor was a 120V to ground leg then you will be okay...
Hope you understand where I was going with this...
heatman101
Oct 27, 2010 | Dayton 2YU44 Electric Heater
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
I have 3phase in my shop. I have a new machine that is rated for 208v 3ph. how can I tell what my incoming voltage is?
You will need to take the cover off of the breaker panel. Find the three lugs that the incoming hot wires are hooked to. With three phase you will have three hot lines. Check the voltage between the phases. L1 - L2- L2- L3- and L1 - L3 Also check the voltage from each line to ground. If you havw 120/208 three phase current you will have 208 +or- a few voltage between the phases and 120 or so from each line to ground. If you have 120/240 three phase you will have 240v across the phases and 120 to ground on two legs and 208 to ground on one leg, this is called a "wild" or high leg. You may also have 480v into the shop and you will know that very quickily if you get 480v between phases. No matter if you have another voltage, you can buy a trandformer that can convert whatever you have to 208/120 3 phase for your unit.
Nov 15, 2009 | Jackson 25 in. TempStar HH Free-standing...
Change 208v heating elements to 240v.
If your supplying 240 vac to a 208 vac element it will work but shorten the life of it.Goto 3wire.com and register,they should have a 208vac element.The wild leg could also be an issue but if you get a 208 vac element it shouldnt hurt it that much.Why you would be getting a reading of 240 vac on l1-l2-l1-l3-l2-l3 is strange.Let me know.
Mar 25, 2009 | Cecilware EFS-40 Deep Fryer
Hobart DGC504  Stainless Steel Kitchen Range Logo
152 people viewed this question
Top Hobart Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Hobart Kitchen Range Expert? Answer questions, earn points and help others
