Question about HP Mini 1000 Netbook
One thin green line down computer screen any idea how remove it
  • 449 Answers
Unfortunately, a thin straight line of any color on an LCD screen is an indication of a hardware failure in the LCD screen itself. The only fix is to replace the LCD screen.
Posted on Apr 10, 2011
50 inch hitachi ultrvision tv with a thin black line going across..and 2 red,1 green thin lines going vertically tv is 7-8 years old...is this a cheap fix or just get a new tv?
screen connections, not a job for the amiture as it relates to the screen connections on the ribbon, you need to remove screen, then with a large area to work with thats flat remove the screen casing and then remove the boards and then the screen ( paper thin) this is the dangerous part as you can brake the screen or even cut yourself. you need to remove screen and place down on a large flat area (padded flat) and you will see the ribbons on the side of the screen. you need a heat gun or soldering heat gun and heat them up and without moving the alignment push down on them so they stick back down, a roller helps as keeps the air from getting stuck in the seal, after put some heat tape over the connection/s each line relates to a connection on the screen. when refitting put pads that are the right size and shape over the connections before fitting the case, then the problem will not happen again with the screen but like i say its not for the amiture to do as it takes patients to remove screen and you have to keep it level at all times or it will crack.
Nov 28, 2017 | Hitachi Televison & Video
What might be the cause of a thin green vertical line running down the center of screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 17, 2015 | Televison & Video
Thin vertical green line
Could you please specify what type of screen this is? Or any other information that could help identify what type of screen it is?
A thin vertical line in a screen could be a faulty cable, faulty graphics card or even that the screen is faulty itself. But with more information on the screen the problem would become clearer.
Aug 27, 2013 | Dell Computers & Internet
LG Flatron screen with green line
Hey man the screen is having manufacturing fault ...
please go and replace it immideatly.... with no doubts in your mind
regards
Sep 18, 2009 | LG Computers & Internet
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Getting green interference on lcd tv especially on
unplug your lvds cable going into the control pcb reconnect cable into the control pcb.if this does not work replace control pcb first,then also could be a defective panel.
Jul 15, 2009 | Televison & Video
I have an orange line down the middle of my screen
i have a thin green line down my computer screen how do i get it off ?
Jun 29, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Lines on screen
laptops do not have degausing thats only on rct screens what you have is a pixil problem and the lcd or plasma is in need of repair or replacement, if your laptop is under warrinety i sugjest you bring it in soon.
Sep 13, 2008 | Dell Inspiron 2200 Notebook
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Thin line across computer screen
This might be a mediaplayer issue. Google on EHtray.exe and you will find a microsoft page with a number of filenames related to these kind of problems. Check by pressing CNRL-ALT-DEL and check if you see any of the filenames on the processes tab. Than stop the file and see if the black line disappears.
Jul 05, 2008 | HP w17e Monitor
HP Mini 1000 Netbook Logo
396 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
