Question about Troy-Bilt Garden
Kohler K181T engine that has been sitting for years not sparking at all. Where to start? Already tried a new plug? How do I check the magneto?
  • 1 more comment
  • bgbevill Apr 10, 2011
    Read the article and I already know I am not sparking, even with a new plug. I know this tiller has points, condenser and magneto. I am trying to find a condenser, the points look fine and I have a new plug. I've searched all over the net and haven't found anything on actually checking the magneto. I plan on pulling the flywheel in a bit and looking underneath it to see if anything is obviously out of order. This tiller has been sitting for just over 20 years, but it ran fine when stored and mechanically it is perfect. Just trying to see if I can get this engine started before I consider a new one.
    Thanks. I have the manual and have read section 8. My engine has no battery or alternator. I removed the flywheel and cleaned the magneto and the magnets. I replaced the condenser and the breaker and still no spark. I've cleaned all the connections. I just got the carb back together, but haven't tried it because I see no need to until I get the plug to spark. I don't recall seeing the low oil level wire you speak of, but I will look again for that tomorrow. I have already replaced the oil.
    Okay thanks, I knew I didn't see a low oil level wire. I am a hvac technician that can tear into and repair most any hvac system out there, but I'm not a small engine mechanic. I purchased this tiller new in 1984 and stored it in 1991 and am trying to get it going to till a spot for my grandsons. I am suspecting the magneto isn't producing any currect, but I am the sort that likes to prove a part is bad before just swapping it out.
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
Go to this link:
http://www.kohlerengines.com/manuals/landing.htm
Choose (1st option) K-series
Then choose 1 - 10 Hp
Then select Horizontal
The Service and owenrs manual for the K181T will appear down the page.
Click on Service
Click on English
The service manual will load (tp_2379.pdf) (well over 25 mb download)
I suspect that you have some corrosion issues with the engine shut off wire or in the Ignition unit area. However..... the engine should have a low oillevel sensor. Make sure the engine is fully serviced with oil then re-check spark. If still no spark disconnect ONE wire from the low oil level sensor and recheck spark. If you have spark with the oil level sensor disconnected clean it with carb cleaner and re-try spark test with it connected.
The manual is taking to long for me to download and 30 min time window here is approaching. I will respond again when the manual finishes down loading.
Thaks for choosing FixYa,
Kelly
Posted on Apr 10, 2011
  • 4 more comments
  • Kelly
    Kelly Apr 10, 2011
    Using the manual (over 28 Mb) Go to section 8 to answer your magneto questions. See page 75 of the pdf file on how to measure breakerless ignition coil resistance. The manual says this is a battery breakerless igniton. You must have alternator power on terminal A of the ignition coil to get ignition.
    Also you have breaker points in your ignition system. Make sure to clean the ignition point contacts and check it for grounds. (Figure 8-8 on page 76)
    If the alternator is grounded or not woking you will not have spark.
    Kelly
  • Kelly
    Kelly Apr 10, 2011
    After reviewing the service manual there is NOT a low oil level sensor so disregard previous oil level sensor comment.
    This is a pretty basic ignition system.
    1. must have alternator out put
    2. breaker / contact points must be functional
    3. Ignition unit must not be grounded.
    You should be able to sort this out. I would NOT go looking for a new engine anytime soon. One thing I would recommend that you do is to remove the crankcase breather and clean it really well. On an engine that has sat for 20 years it could very well be stuck. If when you do get it going you see massive amounts of white smoke... suspect the crankcase breather assembly.
    Kelly
  • Kelly
    Kelly Apr 11, 2011
    For some reason I lost my last post. See page 72 figure 8 - 2 and look at the thin wire(s) that says to breaker point and condensor. If I remember correctly there are 2 wires on the condensor. One of them is a kill wire. If there is a ground any where on this wire it kills the ignition. Find the ground that is on that wire and you will probably have spark. If there is not a ground on that thin wire.... the prime suspect is the magneto itself.
    Kelly
  • Kelly
    Kelly Apr 12, 2011
    Been thinking about how to explain to you the principles of operation of a Magneto circuit. The magneto is a coil and the wire that goes to the condensor and breaker points are the primary coil. The only operating system ground is on the secondary winding high tension spark plug lead. (I.e the spark plug is the operating ground.) To stop the output the primary wire going to the condensor and breaker points is grounded. (kill wire) When you have no output / spark the troubleshooting is to make sure that the breaker points and condensor are NOT grounded. If they are not grounded then the magneto itself has failed. The figure 11,500 ohms comes to mind when checking resistance of the high tension lead to the condensor / breaker point wire. You may have to just read it to the armature / metal part of the magneto.
    Kelly
  • Kelly
    Kelly Apr 15, 2011
    Just doing a follow up on your K181T engine. I was wondering how it is going on the find the spark search? I just hate to see you give up on this as I know it can be fixed. Some feedback when you get around to tinkering with it again would be greatly appreciated. Thanks.
    Take care,
    Kelly
  • John Oliver Feb 18, 2013
    I had the same problem before from several types of engines. Sometimes taking a little fine emery cloth and brushing the points will do wonders, even if there new. Sometimes the have a protective film on them. Second thing is the flywheel magnet. I have a troy-built horse with a k 181T on it. Having the same problem I bought 3 magneto assemblies. Niether fix the spark problem. Tested the magnet and it was weak, not having 500.00 bucks for a new flywheel and couldn't find a place to remagnetize this one. I installed a battery, coil, and wiring. Wa-lah no problems now. Cranks right up, but I do have to charge the battery at night. Still trying to find a good flywheel so I can change it back though.
    Brigadier General:
  • 3,917 Answers
Hi
Given bellow is a detailed article from where you can have an in-depth knowledge related to your issue:-
http://www.motherearthnews.com/ask-our-experts/engine-start-problems.aspx
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
What supplies voltage to spark plugs?
The spark on the 25 hp Kohler is Magneto. There is likely an interlock to the PTO and Seat safety interlock. The magneto appears in some lawn garden applications to be connected via the safety interlock?
So when the engine turns the magnetic field of the flywheel activated the engine spark but if the interlock safety switches are not enabled the spark the magneto is disabled resulting in no spark. A lost spark is likely a defective or corroded switch.
I hope this helps?
Jan 11, 2016 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Kohler courage 6.5hp wont start?
Could be a short in the coil for the sparkplug. Check the magneto- pull the plug wire off the spark plug and hold it close to the frame of the while someone tries to start it. Keep all parts of your body clear of the mower- only hold the sparkplug wire. When the motor turns over, verify spark from the wire to the frame. If no spark, you likely have a bad magneto coil. If you have a good spark, try taking the air filter off and use some engine starter fluid (not much) and then try and start again. If it starts and runs for a second with the starter fluid, you probably have a problem with your fuel not getting in, which leads to troubleshooting the carb and intake.
Apr 26, 2014 | Cars & Trucks
Craftsman LT2000 w/ 18.5 HP B&S engine- will not start-been sitting up for year in shed- new battery- checked fuel flow to carb: OK - checked spark plug: cleaned , seems OK- engine turns over but not...
A 'cranks but doesn't start" problem just needs to be narrowed down to compression,fuel,or ignition.The compression is pretty obvious-does it sound like the stater is getting a load when cranking?The next one is fuel-do you smell raw gas fumes coming out of the exhaust?The last one is spark-take the plug out and clamp it to the block,crank it,do you see a spark? If you have compression and spark,try a shot of starter fluid down the carb.(sometimes the float needle can get stuck,and just getting the engine to fire will shake it loose).If you don't have spark,then look for why(not sure if you have a magneto or ignition coil system).
Apr 14, 2012 | Craftsman Garden
My honda 5hp pressure washer was working fine. It was sitting in my basement for a year now will not start. There is no spark so bought a new Ignition coil but still no spark what could it be please?
it could be the stator. its an alternator for small engines. try a new plug wire and if thats not it may be the kill switch. if not its a possibility its the stator. some call it a magneto.
Jul 09, 2011 | Garden
What would cause no spark? the mower is a masport 8/02 two stroke. Will not start and I have changed spark plug and cleaned every thing but still nothing.
Your spark plug wire may be damaged, or your magneto may be too weak to generate a spark. You also have a kill switch wired to your magneto, and a condensor. I would start by cleaning the contacts of the magneto and then check the gap between the magneto and the flywheel. The gap between the flywheel and magneto should be .010". I would start by checking the kill switch wire for damage. If any damage is suspected, replace the kill switch. Next, I would have the magneto tested or replaced. Also, check all your ground wires for damage, or loose contacts.
When you are checking for a spark, you should have the spark plug installed in the spark plug wire as normal, but not installed in the engine. The spark plug base should be grounded to the engine while trying to start and checking for a spark. If there is a weak spark, this is probably due to a worn magneto.
May 24, 2011 | Briggs & Stratton Garden
Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Scotts 2554 mower wont start added new battery, cleaned carb and needle seat. new pto switch but still pops fuse when u pull the pto switch, put new swi=tch in and now wont even turn over at all
Does the engine turn over?. The pto switch you mentioned is this the POWER TAKE OFF switch? In other words starts the deck? If so, it must be off when starting the mower. Any internal combustion motor needs fuel and spark. If it cranks over check for a spark. If no spark determine if it has points or breakerless ignition. Also check magneto coil. If you have spark then, be sure fuel is getting to the carb. With today's gasoline, you can't let it sit in the tank long without adding an additive. If the PTO switch you described, is blowing a fuse, then it cold be a bad coil on the clutch. You can disconnect this coil to see if it stops blowing the fuse. you didn't mention if it is a Kohler or BS engine. Try this link:http://manuals.deere.com/cceomview/OMM141871_D0/Output/OMM141871_D014.html#34531
Jun 30, 2010 | John Deere Garden
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
No spark on my 14 hp kohler engine
Sometimes there is rust on the crankshaft and the magneto can not pick up the signal. Leave the sensor on the engine, try cleaning the rust off the crank damper and then run a clean rag between the sensor and crank. The gap varies but a old fashion matchbook seems to work in case the sensor is loose. Good Luck
Jul 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
756 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
