Question about Panasonic RF-544 Radio
Panasonic RX-D10 I can hear the power going on. Small tuning screen does not activate. done everything apart from opening it up, which I dont want to do as as I'm clue-less. The radio is in a room with two wireless broadband devices.
  • 1 more comment
  • commerciante Aug 07, 2008
    Tried taking the radio out side. still tuning responce
    Tried taking the radio out side. still no tuning response
    thanks to all will try the earphone...
    Genius:
  • 1,689 Answers
Well the wireless AP can be the least of the issues, supposedly even if the antenna is broken, it should give you noise. the device has an earphone port,will you try to check if that is working because if it is, you may want to check on the speaker connection in your RX.
Posted on Aug 07, 2008
  • 876 Answers
Wireless devices do use radio frequencies. Have you taken it elsewhere ? This is just a bit of knowledge I found floating around in my head. It could be that the device won;t work work in that area.
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
Emerson Jumbo Universal Remote won't program Direct TV receiver.
Have you tried doing this:
Press and hold the TV button on the remote till all 4 buttons light up and flash(make sure your TV is on). Once they flash, press the power button, then using the channel up button, point the remote at the TV and keep pressing it till the TV turns off. When it does, press the # sign and that will lock in the new found code.
Hope that helps........
Jul 21, 2008 | Televison & Video
The roland d10 powers up but none of the buttons or keys work? the screen just says "roland d10 synth"? please help!
The unit name is part of the boot sequence, it should go beyond that and boot up completely. If it gets stuck there, there is surely some problem. Maybe a depleted internal battery, I don't know. Ask a local service center, maybe there's a combination of buttons you could check out while on the phone prior to bringing it in for repair...
Jan 07, 2013 | Music
I bouhgt replacement battery for my jet bok, but dont know how to change it?
Remove the small round rubber covers on four corners, no need to open the two bigger ones
now comes the toughest part
try to push in a small screw driver through the edge, do it gently and preferably on the lower corner,so that u dont damage screen in case u slip.
once u get a small opening try to take apart the cover.
this requires a lot of patience but once u get an opening of a inch or so it becomes easy
then when u are done with removing the whole cover u will c the battery
find the connector and again with a small scerw driver gently push away the connector, again lot of patience.
Again the connector of the new battery has to be put in carefully.
Once its pushed in all the way u r done.
Close the cover and charge the battey for atleast for 10 hours.
U r done with the replacement
May 07, 2012 | Ectaco jetBook
No sounds . no voice . no noise on numbers. cannot hear people talking. cannot hear voice mail. will ring. cannot answer
take it your phone has been dropped a couple times? lol..
Does the screen work normally? either way if you havent fixed this yet (seeing as this is 23 days old as i post) your going to have to take your phone apart. you can try the easy way and take the bottom half apart but dont try to take the screen off. there is a flimsy ribbon cable that runs from the top corner of the bottom half through the hinge that is easier than heck to break. after you get the bottom half apart try pressing down on the plug of it to see if it is loose then try your phone again.
the reason i asked if the screen is working is because that one cable usually handles everything in the top half and when one thing in an electrical device (expecially a small one that has a bunch of tiny components) doesn't work there can be no telling what else will go with it
Nov 12, 2010 | LG VX8350 Cellular Phone
Loss of Signal
Please make sure the antenna is tuned to proper SWR.
Also double check the power wire connections.
Let me know if you have no clue about tuning the SWR.
May 26, 2010 | Cobra 19 DX IV CB Radio
Panasonic Compact Audio system SA-HM32
Hi Desmondia,
Sorry but the bulb replacement is not a simple as it used to be....The screens on modern sound systems are made up of small crystals that glow when activated by electrical current of very small strength..
These are called LCD Liquid Crystal Displays, or could be very small chips like Light Emitting diodes arranged in an alphabet configuration. I dont know which one your particular amplifyer system has,,,
These dispalys are controlled by a fast scanning oscillator which up dates the screen dispay so fast that the screen display shows the information you need to see.
In fact the screen information is going on and off so fast you dont even know its happening .
Anyway to keep this story short the screen display in your case
appears to have stopped scanning..Its a major repair job...
needs to go to a reapair shop for a cost quote to fix for you.
Cheers From YUBEUT
Feb 10, 2008 | Audio Players & Recorders
LCD kaput - anyone know of a panasonic recall?
The panasonic camcorder does not use the Sony CCD element. If the small viewfinder is showing the camera video, there's nothing wrong with the CCD imager. We have had numerous problems with the switch that controls the activation of the large LCD and the backlight inverter that powers it. When you open the LCD the small viewfinder should power down to conserve battery power. The large LCD should then illuminate, if not, shine a flashlight at the surface of the LCD and notice if the video is present, if so, the backlight or LCD harness is defective. Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | Panasonic Palmcorder PV-GS120 Mini DV...
Samsung VP-D10 Mini DV Digital Camcorder
hi, I wish you wouldve given us more details regarding the kind of distortion you get on the LCD screen. if objects kinda fuzz out, it can be related to worn headdrum, i.e. worn heads. The heads are tuned with the input-capacitance of the PB-amplifier on the white-frequency of the recorded RF(is in FM with high frequencies on white) . The wear of the heads will decrease their inductance so the tuned frequency is going up.The video-amplifier and demodulator circuits can`t compensate it. Another reason can be a misaligned FM modulator( frequencies for black and white are not set correctly). Finally the AVC of the camera itself can be faulty. The guiding posts will never cause such problem but their setscrews tends to get loose. Tighten them carefully. Good luck
Mar 27, 2006 | Samsung VP-D10 Mini DV Digital Camcorder
Panasonic RF-544 Radio Logo
172 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
