Question about Husqvarna 20HP Hydrostatic 42" Cut Riding Mower
Where is the tube or plug i pull to drain oil. i have already removed the filter.
How to change a fuel filter on a polo vivo 2010
Engine oil: Drain or extract and replenish; renew oil filter Engine oil: Drain or extract engine oil ? Chapter. Renewing oil filter ? Chapter. Replenishing engine oil ? Chapter. Draining or extracting engine oil Special tools and workshop equipment required t Used oil collection and extraction unit -V.A.G 1782- t Oil spill cloth -VAS 6204/1- Draining or extracting engine oil Carry out the following procedure: > Note
t For engines with standing oil filter the oil filter must be renewed before changing the engine oil. When removing the filter element a valve is opened, the oil in the filter housing automatically flows into crankcase. t If the engine oil is drained and not extracted with an oil extractor, replace drain plug. This prevents leaks. t Observe disposal regulations! - Extract engine oil using used oil collection and extraction unit -V.A.G 1782-. or - Remove oil drain plug. - Let engine oil drain. > Note
t The oil drain plug is fitted with a secure seal, therefore the oil drain plug must always be renewed. t Observe disposal regulations! - Screw in new oil drain plug with seal hand-tight. - Replenish engine oil, specification ? Chapter. Engine oil capacity: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. Specified torques for oil drain plug: t Petrol and diesel engines 30 Nm > WARNING
t Torque specifications must not be exceeded. t Excess torque can cause leaks in the area of the oil drain plug or even damage. Renewing oil filter Renewing oil filter, 1.4 l and 1.6 l injection engines > Note
t Prevent engine oil from dripping onto components in engine compartment. t Oil new O-rings before installing. t Observe disposal regulations! Renewing oil filter, 1.4 land 1.6 l engine Carry out the following procedure: alt="W00-10211"> - Unscrew cover cap -1- with socket insert 36 mm AF and remove cover with oil filter insert -4- and valve -5-. - Renew O-ring -2- of cover cap and O-ring -3- of valve. - Renew used oil filter element with new filter element. > Note
Observe disposal regulations! - Tighten cover cap -1-. Cover cap torque setting: 25 Nm. Replenishing engine oil Oil specifications ? Chapter Engine oil capacities: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. General notes > Note
Observe disposal regulations! - After replenishing with oil, wait at least 3 minutes and then check oil level. - Pull out dipstick, wipe with a clean cloth and push dipstick in again to limit stop. - Pull dipstick out again and read oil level. alt="N01-10183"> For dipstick as illustrated: A - Oil must not be replenished. B - Oil may be replenished. It may happen that the oil level afterwards is in the -A- region. C - Oil must be replenished. It is sufficient if the oil level is in the -B- region (hatched area) afterwards. There is a danger of damaging the catalytic converter if the oil level is above the -A- marking. - If oil level is below -C- marking, top-up oil to -A- marking. alt="N01-10255">
Mar 14, 2015 | Volkswagen Polo Cars & Trucks
HOW DO YOU CHANGE OIL ON A briggs and stratton diamond i/c 15.5hp vertical shaft ride on mower
find the drain plug on side of engine usually near oil filter take out drain plug drain oil out replace plug remove filter install new one fill oil in filler tube check with dipstick until level reaches safe on the dipstick done
Aug 25, 2014 | Briggs & Stratton Garden
Removing the drain plug and oil filter on a 2005 pontiac vibe
They sell octagon shaped oil filter wrench that conforms to your oil filter's shape. Take your replacement oil filter, then call the auto parts store in your area and ask if they carry oil filter wrench for your car, If a standard filter wrench keeps slipping off, wrap 2 or 3 layers of rag to the old oil filer, then attach the oil filter wrench. The drain plug turns left to loosen, right to tighten. If you're using a socket wrench, attach a 1/2-inch pipe to the handle to increase leverage (cheater pipe). Another solution is a strap oil filter wrench
4ec92b1e-c8dd-4d72-80fb-d33e80108759.jpg ffea9219-514a-4c9b-9a3c-0e0d08ec1f7b.jpg 78fa3f58-edb2-447b-9cd0-64dadb0810b9.jpg
Mar 19, 2014 | Cars & Trucks
Where is the motor oil drain plug on flxh
This is straight from the repair manual:
1. Ride vehicle until engine is at normal operating temperature.
2. Locate oil filler plug/dipstick on right side of vehicle at top
of transmission case. To remove the oil filler plug, pull
steadily while moving plug back and forth.
3. Locate oil drain plug at front left side of the oil pan.
Remove the oil drain plug and allow oil to drain completely.
4. Inspect the oil drain plug O-ring for cuts, tears or signs of
deterioration. Replace as necessary.
5. Remove the oil filter as follows:
a. Obtain the OIL FILTER WRENCH (HD-42311). The
tool allows easy removal of the oil filter without risk
of damage to the crankshaft position sensor or
cable.
b. Place the jaws of the wrench over the oil filter with
the tool oriented vertically. See Figure 1-1.
c. Using a 3/8 inch drive with a 4 inch extension, turn
wrench in a counterclockwise direction. Do not use
with air tools.
NOTE
Use OIL FILTER WRENCH (HD-44067) if HD-42311 is not
available.
6. Clean the oil filter mount flange of any old gasket material.
7. Lubricate gasket with clean engine oil and install
new
oil
filter on filter mount. Hand tighten oil filter 1/2-3/4 turn
after gasket first contacts filter mounting surface. Do
NOT
use OIL FILTER WRENCH for oil filter installation.
NOTE
Use of the Premium 10 micron synthetic media oil filter is
highly recommended, Part No. 63798-99 (Chrome) or 63731-
99 (Black).
8. Install engine oil drain plug and tighten to 14-21 ft-lbs
(19-28 Nm).
9. With vehicle resting on jiffy stand, add 3-1/2 quarts (3.3
liters) engine oil as specified in Table 1-1. Use the proper
grade of oil for the lowest temperature expected before
the next oil change.
Apr 05, 2011 | 2008 Harley Davidson FLHX Street Glide
Number of litres for oil change for a 660 t artic cat turbo
You need about 3 liters of Mobil 0w40 synthetic oil. New oil filter.
There is a plug on the belly pan of the sled. Pull that off.
Then there is a oil drain plug on the oil pan of the sled(look through the hole in the belly pan)
Pull the oil plug and drain old oil.
If you have a turbo, take off the intercooler tube, and then put rags or papertowel below where the oil filter sits.
Spin off the oil filter (this might be real hard and some have resorted to driving a screwdriver through the filter to get it off)
After all has drained..
Put in oil pan plug.
Put in belly pan plug.
Spin on new filter, put a little oil on gasket first.
Replace intercooler tube.
Then refil from the top of the motor with 2.5L of oil.
Checking dipstick as you fill.
Then start motor for a second or two, to fill filter.
Top off the oil and recheck the dipstick until it reaches the full line.
It really is very easy and after you do it once, you will be an expert at it.
Dec 30, 2010 | Sport & Outdoor - Others
HOW TO CHANGE OIL PAN ON F150
Hi. Here's the procedure on how to change the oil pan.
Things You'll Need:
Drain pan
Crescent wrench
New oil filter
Oil filter wrench
Socket wrench
Socket set
Razor knife
Putty knife
New oil pan
Oil pan gasket
6 qt. of oil
Clean towel
    Draining the Oil
  1. 1 Locate the oil pan directly underneath the engine. The oil pan will be held on to the bottom of the motor by 16 to 18 bolts. The drain plug is at the bottom of the pan.
  2. 2 Loosen the drain plug with a crescent wrench. Allow all the oil to drain in to the pan. Tighten the drain plug when the oil is through draining.
  3. 3 Unscrew the oil filter with an oil filter wrench. Place the oil filter with the waste oil.
  4. 4 Rub new motor oil around the gasket of the new oil filter. Pour 1 qt. of oil in to the filter.
  5. 5 Screw the filter to the filter housing with your hands. Do not wrench-tighten as this will strip the threads and make removal of the filter difficult.
  6. Replacing the Oil Pan
  7. 1 Locate all the bolts holding the oil pan in place. There will be 16 to 18 bolts.
  8. 2 Unscrew all the bolts with a socket wrench. Lower the pan to the ground. If the pan is stubborn, tap it with a rubber mallet to loosen the seal from the gasket.
  9. 3 Scrape clean all the gasket material around the bottom surface of the motor. This will ensure a tight seal with the new oil pan.
  10. 4 Place the new gasket around the new oil pan. Raise the oil pan to the motor and screw in all the bolts. Do not tighten the bolts until all are threaded to the bottom of the motor.
  11. 5 Tighten the bolts with a socket wrench. Ensure that all the bolts are tight.
  12. Adding the New Motor Oil
  13. 1 Open the hood to access the engine compartment. Unscrew the oil filler cap on top of the crankcase. Pull the engine oil dipstick from the tube. Wipe the dipstick clean with a fresh towel.
  14. 2 Pour in 5 qt. of oil in to the engine crank case. Insert the dipstick back in to the tube and pull it back out. Check the oil level against the markings on the dipstick. Fill at 1/2 qt. intervals until the dipstick indicates "Full."
  15. 3 Start the truck and allow it to run for five minutes. Allow the truck to sit for an additional five minutes to allow the oil to drain back to the oil pan.
  16. 4 Check the oil level again. Fill if necessary, but do not overfill.
Sep 21, 2010 | 1995 Ford F150 Styleside Regular Cab
How do you change the oil on a 2006 chevy colorado
This is for the 5 cylinder 3.5 liter engine in the Colorado
1. The drain plug is in the middle of the oil pan on the drivers side.
Use a 15 mm socket or box end wrench to remove the plug. Drain
oil.
2. The oil filter is at the bottom front corner of the engine on the passenger side. Remove the filter. Try not to tip the filter when you
remove it so you don't get oil on other parts of the truck.
3. Rub a small of oil on the gasket of the new filter. Spin on the new filter, 3/4 to 1 turn past when the gasket starts to seat. Hand tighten
only.
4. Reinstall the drain plug. DO NOT OVER TIGHTEN OR YOU COULD
STRIP THE THREADS.
5. Add 6 quarts of oil to the oil filler tube located on top of the engine
in the front and middle of the engine compartment. It shows the location
in the owners manual. Install the filler cap.
6. Start the engine and let it run a few minutes to fill the filter with oil.
Turn off the engine and wait a few minutes for the oil to drain down to
the bottom of the engine. Remove the dip stick and check oil level.
Checking oil level is in the owners manual.
Aug 10, 2010 | 2006 Chevrolet Colorado
Oil pump ,,,where is the oil pump located on a 1997 dodge caravan
Hello
Welcome!
Oil pump is located on the oil pan.
Parts needed,,,oil,,,, oil filter,,,, oil pan gasket,,, oil pump,,,, oil pump pickup tube..
time to do this,, about 3 hours
Instructions,
Raise van place on 2 jack stands
drain oil remove oil filter fill new filter install.
remove bolts from oil pan,
remove oil pan..
remove 2 bolts that hold oil pump and tube.
install new pump and tube tork bolts to 45 fp
replace oil pan gasket and install oil pan
tork pan bolts to 35" pounds
install drain plug
fill with oil
start and check for leaks
let me know if i can help more
Jul 17, 2010 | 1997 Dodge Caravan
How to oil change 2005 Mercedes Benz E320 Cdi
Mercedes makes it easy! Get a 10 quart oil pump and draw the oil out of the dipstick tube. The oil filter is on top so can be removed with a filter wrench and easily replaced. No need to jack the car up or crawel under. No fuss no mess and a 10 minute oil change!!!
Mar 24, 2010 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
How do i change the oil?
jack the car and support it on jackstands. put a can or oil catcher under the oil drain plug then loosen but do not remove the plug. slowly start to remove the plug letting oil drain out . when all the oil is drained remove the filter using a filter wrench available at most auto stores for under $10. hand tighten the new filter acoring to the instructions on the filter then replace the drain plug. Now add up to the specified litres of oil and check under the car/truck for leaks around the drainplug and filter. now you are done
Sep 07, 2009 | 1997 Ford Expedition
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
