I would like to know what type of cable to buy, if it is just that, or if it is possible to hook my laptop to my tv, which is a flat screen vizio
  • 27,725 Answers
Yes you will need a vga lead this will attach to the vga outlet usually on the side of your laptop with 9 pins but you will have to change your computer settings to an extended desktop
click start control panel display adjust resolution another window will open with number 1 and 2 with a detect and an identify tab once you have identified the extended desktop click apply
hope this helps
Posted on Apr 10, 2011
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I can get sound, but no picture when I have my laptop hooked up to my tv (a Vizio). How can I solve this problem?
you might have to change your screen resolution on the laptop, it's possible that it is set too high.
Feb 20, 2015 | Vizio L32 32 in. LCD HDTV
I have an asus Eee PC Seashell series netbook and I'm trying to connect it to a vizio smarttv but it keeps showing "no signal" on the tv
Have you checked these?
1. Input settings in the TV,
2. Cycle the laptop output (laptop screen, external screen, both)
Mar 10, 2014 | ASUS Eee PC 1005PE (SeaShell) Netbook
Type of Cord to hook Laptop to TV
You need a standard VGA cable to go from the laptop to the TV. Keep in mind that the sound will still come from the laptop not the TV speakers. You can get a cable here if you need one.
http://www.ccl-la.com/catalog/product_info.php?cPath=83_87&products_id=54
Jul 15, 2012 | Vizio SV421XVT 42 in. LCD TV
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I just purchased a vizio 37 in tv. I wanted to know about the best hook up for the tv to the direct tv box.
If your Direct TV box is HDTV compatible then the best connection would be HDMI, and Componant Cables (Red, Green, Blue, w/Red, White) would be the second choice.
If your Direct TV box is not HDTV compatible only SD compatible, the best connection would be S-Video (S-Video cable with audio cables), Composite Video (Yellow, w/Red, White), or Coax cable.
All of the above cables can be purchased at your local Radio Shack, Best Buy, Walmart etc..
Feb 08, 2010 | Vizio Televison & Video
I have a vizio vw32L40a and the screen is too wide. there are only wide and stretch settings, no normal setting. the screen is too wide for the tv.
6/09 I had the same problem when receiving the signal over the air with the input set to TV. Perhaps the signal strength or type was varying. At any rate, after I hooked up HD cable and watch from that input, the problem no longer occurs.
Jun 27, 2009 | V, Inc. Vizio P50HD Plasma Television
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
