Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer is showing Error 6A00, blinking green and orange lights
    President:
  • 3,278 Answers
Hello.
Error 6A00 is a problem with the sheet feed unit and is related to the purge unit being jammed with something and not being able to move.
Give this a try (resetting the printer): Unplug the printer from the power source while the printer was still on, wait 60 seconds and plug back in.
Also, clean out under where the print heads are parked. Lift and gently shake the unit as necessary. You may find paper clips or other debris.
If still a problem, then unfortunately, you will NOT be able to resolve this problem yourself.
Take it or send the unit to the Canon Authorized Repair Facility.
Hope this helps.
Posted on Apr 10, 2011
Error 6A00 when attemnpting to print from Canon IP3000 printer.
According to the service manual of the printer, the Error 6A00 is one of the Service Call Errors (by LED blinking in orange and green alternately 12 times.) The name of error is “AP position error [6A00]”. The sheet unit (QM2-1220) or Logic board ***’y (QM2-1520) may be faulty. And the replacement of the part is needed which is likely to be faulty.
It means that you have to waste money.
But you can try the solutions below:
Solution 1:
It looks like the print heads need to dip down into the small sponges underneath the white plate at the end of the start motions. Just move the print head carriage (white plate) back and forwards a few times.
Solution 2:
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. This may be related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. The offending item needs to be removed or the purge unit needs replacement.
Solution 3:
Press the ink pads down in the purge unit.
Solution 4:
After trying the solutions above to reset the error:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Error message 6a00 showing on screen orange and green lights flashing checked to see if any paper jammed but it is clear
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Jan 17, 2010 | Canon MP610 Photo All-In-One Printer
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Jun 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON MP830 PRINTER ERROR CODE 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Mar 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon printer mp830
I had the same problem with my Pixma MP830 printer giving me a 6A00 error indicator. I solved my problem. Hope this will solve yours too. I moved the printer head over to the left. I noticed two black pieces of paper or sponges attaced to a spring on the right hand side where the head is at rest when not being used. I with a paper towel absorbed a little of the black in off the paper or sponge like material. I found the two white long pieces held by the spring were forward and would move. I used a ball point pen and moved the closed piece with the spring attached to the rear of the printer and it remained there. I surmised it was out of place because when I started up the printer again my 6A00 error code was gone and my printer was working again. It took me a long time to get to this point (like 6 hours) but that saved me from taking my printer in and spending like $80.00 or more for them to take care of the problem. Hope this helps you fix your Canon Pixma MP830 printer or other models giving the same error code to you.
CALL ME DON W
Nov 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
