Question about Astoria Argenta SAE-3 Espresso Machine
How do I clean the steamwands - Astoria Argenta SAE-3 Espresso Machine
    President:
  • 1,618 Answers
Soak in a solution of purocaff and hot water, then clean out nozzle with a paper clip.
Posted on Apr 14, 2011
Not regular steam
First make sure that the nozzle is absolutely clean... If it is so, its most likely a problem with the mechanical steam valve spring. It could be that the spring is broken or even a pivot screw has come loose... You may need to open up the valve to check and clean
Feb 25, 2013 | ECM Giotto Espresso Machine
Tip
Furniture Cleaning/Polishing/Dusting Atlanta GA 678-954-7553 House Cleaning...
HOUSE CLEANING SERVICES ATLANTA GA 678-954-7553 OFFICE CLEANING - ATLANTA,CANDLER PARK,EDGEWOOD,KIRKWOOD
24/7 Cleaning Services decatur GA.678-954-7553 House Cleaning Services
Professional Residential,Commercial and Industrial Cleaning Services
YOU MISSED A SPOT http://www.cleaning-services-atlanta.com
HOME OUR COMPANY OUR SERVICES JOIN THE TEAM REQUEST SERVICES SERVICE AREAS CONTACT US
CSA Foundation-helping premature babies with critical illnesses : 24 7 Professional Cleaning Services Serving All Areas of Metro decatur Georgia. Cleaning Services decatur utilizes the most effective antimicrobial, antiviral, disinfectant/decontamination products on the market.
Residential Services | Commercial Services | Move Out Cleaning | Window Cleaning | Tile Grout Cleaning | Hardwood Floors Polishing
Carpet Vacuum and/or Deep Cleaned
Floors Cleaned and/or Waxed/Refinished
Keyboard and Desk Dusting
Bathrooms Cleaned/Restocked
Offices Cleaned
Exam Rooms Cleaned/Restocked
Waiting Rooms Cleaned
Employee Lounges Cleaned/Restocked
Trash Disposal
Windows Cleaning
Emergency On-Call Service
Trash Disposal
Windows Cleaning
Basement/Attic Cleaning
Lawn Care
Pressure Washing
Rental Properties Move-in/Move-out Cleaning & Painting
Property Abandonment Cleaning
Military/Veteran
Senior Citizen
Disability
Student
Frequent Customer
20% OFF 1 MONTH (+) SERVICE AGREEMENTS CLEANING SERVICE decatur - "LET US DO THE DIRTY WORK FOR YOU"
TESTIMONIALS
DISCOUNTs
COUPONS
CSA FOUNDATION
FAQ's
Cleaning Service decatur provides affordable office cleaning services. Our cleaning maids are honest and professional. Our services include: business/commercial cleaning and residential cleaning; offering windows cleaning, carpet cleaning, tile cleaning, grout cleaning, refinishing hardwood floor, wax floors, garbage and waste management, furniture cleaning, polishing and dusting, and much more. We offer service to the metro decatur population. We accommodate medical offices, business offices, nursing homes, day cares, schools, hotels/motels, etc.; Special Events including: Wedding venues, Parties, Concerts, After Parties etc.
on Aug 02, 2010 | Home
No steam coming from frother
If you are getting hot water from the grouphead to make coffee then the nozzle at the end of the steamwand could be blocked, use a paperclip to clear. If the problem is not fixed after cleaning nozzle then machine need to be descaled.
Oct 02, 2011 | Gaggia Classic Espresso Machine
Water coming from the hot water valve (so right off of the boiler) is cloudy, almost rusty colored. We just had our water changed to a new reverse osmosis system, but were using reverse osmosis water...
The boiler is contaminated if the smells funny, if not then the water is leeching the minerals out of the boiler. RO water is an acid (pure water), it is just as bad as distilled water for espresso machines.
Mar 07, 2011 | Astoria Argenta SAE-2 Espresso Machine
Hi, my machine does not give contant steam through the steamwand - it comes with splurts of water in between which dilutes the milk and makes frothing difficult. I have tried running the steam a few...
The level probe in the boiler is set too high and needs to be adjusted, it is located on the right side of the machine, remove top panel screws for access. You will see the red electrical wire going to the silver prove. Remove probe and clean or adjust.
Jan 28, 2011 | Nuova Simonelli Premier Maxi Espresso...
How to set the timer
Look behind the right steamwand, you will see a little toggle switch with the on label on the left. Move switch to on label then press program button, all light on keypad will be on, press button until desired amount then press same button or stop button, continue until all buttons are programed.
Jan 10, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
A peice(oring maybe) fell out of the steamwand while I was taking it apart. now the attachment will not stay on the wand it just falls off, can I get a new one?
Hi
There should be 2 removable pieces between the cap and the main body. There should be a plastic compression sleeve, and a rubber sleeve. They should look similar except one is hard and the other is soft. The best way to clean the steam tip is to loosen the cap and pull the bottom of, leaving the other pieces on the wand.
Nov 14, 2009 | Saeco Starbucks Sirena Espresso Machine
Water dripping of Steam Wand during brew cycle
If water is dripping out of steamwand then the valve assembly is not working properly and needs to be replaced.
Aug 17, 2009 | Saeco Odea-Giro Espresso Machine
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
Astoria Argenta SAE-3 Espresso Machine Logo
35 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
