Question about Samsung PCN5425R 54" Rear Projection Television
Red picture tube broke at the yoke
Received this tv for free. worked for the first night next day the red was going on and off for a while, then on super red with  a curved picture when it poped and shut down. I said to myself I can fix this ,I went to school for this kind of stuff. Proceded to take back cover off and take look,  after i checked this site for clues I pulled the red plug with blue wires and tried to turn the set on. When I hit the button for the third time I almost soiled myself when  the neck of the picture tube fell. I also noticed what must be coolant had squirted out the breather hole and ran down the side onto the circut board below and looks like it may have done some damage. there is one small greenish-black spot size of a pea going under a capaciter and the board looks wet in that area.Why did this happen? One more thing,the tube part number is P16LFM00RFA(TU)  what is the diference of this # and that # with (AU), and what about using a tube from a green or blue  and change out the lens? (with matching #'s from blue or green).
SOURCE:
premtech
  • 934 Answers
SOURCE: Samsung Rear Projection HD tv IC convergence green only messed up now. Help please
To check the pico fuses you're merely testing for continuity. If you get an infinate reading you're in good shape - if it doesn't budge the meter the fuse is open... That's a really easy set to work on for convergence problems - the convergence board is easily removed..
Another cause for mis-alignment like that are the youke return resistors... There are several out front of the convergence amps that may have changed in value. They are 3.9 ohm - 2w resistors and will look identical to Rz123 and Rz124 (same banding). For those simply select a low ohm setting on the meter and check to see if any of them have some way low or way high reading...
Need anything else just ask...
Bill
Posted on Dec 10, 2007
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
  • 163 Answers
SOURCE: RED OUT OF ALIGNMENT
Smack it on the back closest to the board (Not Hard)..to see if its a Cold sloder joint issue.. (Trust me I've seen issues).. Also Not familiar with the model is it Flat Plas, CRT, LCD?
Talk soon....
Posted on Feb 06, 2008
  • 98 Answers
SOURCE: Color issues
yes try this above links
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Posted on Oct 13, 2008
CAYPIANAN
  • 227 Answers
SOURCE: HCJ552W 55' samsung rear project....won't turn on
dear friend you have a power supply problem, get one of those cheap meters and open the set, look for a blown fuse, if they are ok wich i doubt, you have to call the repairman.
good luck
caypianan@yahoo.com
Posted on Oct 23, 2008
How do i fix a crooked screen on an older tube t.v.?
The yoke needs to be turned slightly and the picture will move in the same direction as you rotate the Yoke. (located on the neck of the Picture Tube) Just loosen the screw on the yokes clamp slightly then carefully touch only plastic edge of the yoke and turn it slightly while an assistance watches the picture be careful not to slide the yoke up hugher or lower on the neck. It has to saty at the same spot but just rotated slightly.The pic below shows the yoke with yellow arraows. Do not disturb the purity rings (RED ARROW) or it will cause blotches in the picture so its very important not to disturb the item with red arrow.
Mar 06, 2013 | Televison & Video
Blue green and yellow base picture no red colour
This could be from a couple of reasons. It could be a transistor, or resistor on the neck board that controls the red gun on the tube if it is a tube tv. It could also be a weak red gun in the tube itself and may need rejuvenated. Or maybe it can also be a bad solder joint on the PCB that connects the yoke connector.
Oct 28, 2012 | Televison & Video
Horizontal driver too hot, no eht, power suply is ok.
Hello
If horizontal output transistor gets over heated, the either LOT or Deflection Yoke may have some short in it. You just pull out the picture tube base card from the picture tube neck, and place it somwhere. so that it never gets in contact with any other circuit parts of the TV. Pull out the deflection yoke plugin and put the tv ON, and see whether it overheats now or not. If it overheats no also, LOT is defective, and should be replaced with a same type and number. If it does't overheat now. put the unpluged yoke connection, and switch it ON. If it gets overheats, there is some short in between the horizontal winding section inside the deflection yoke. Caution:- Never place the picture tube base board connected to it, while deflection yoke is disconnected. OK.
Dec 06, 2010 | Televison & Video
Picture was great day before, next day picture would not come on.
I had the exact problem. Turned it off at night, next day nothing. Set is KV32FV16, manuf. in 2000. Repair tech. found bad fuse that was all, set now working. Fuse located in lower right hand side of chassis. Fuse appeared to have deteriorated rather than blown. Good luck.
Mar 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is slightly tilted
Its an easy adjustment but it requires you to work around the deflection yoke on the neck of the picture tube. Above the yoke is a red connector that is carrying 30,000 volts then on the yoke itself you have wires that are connected to the horizontal and vertical circuits that can carry up to a 1200 volt pulse. So this alignment is not for anyone but a technician. I personally would leave the tilt until you can have a technician touch it up for you. Take a moment to rate my answer. Thanks...
Nov 20, 2009 | JVC AV-32FA54 32" TV
Will not turn on
Resolder,or replaced the FBT,the flyback tranformer,the big black block of plastic with a red wire a cap hook to CRT(tv tube).High voltage prob.
Mar 13, 2009 | Toshiba 27AF42 27" TV
No picture no power red button flashes 4-5 times and shuts off
Try unplugging the 3 convergence yoke plugs and then trying to power on the set. The convergence plugs are located on the board on the left side of the tv looking in from the back and they are 3 identical plugs right next to each other they have a R B and G next to the plugs one letter for each plug just remember which plug goes to which location when you plug them back in.
Jul 16, 2008 | Philips 55P8341 55" Rear Projection...
Loss of colour from top of tv purple at the top with a bit of normal picture at base.is the tube going
Good day. It would have been a different scenario if the problem is your tube. The one that your having is a mere problem with the loose contacts in your units circuitry. Also, the terminals of your deflection yoke must be reoldered..
chris
Feb 17, 2008 | Sharp 20F640 20" TV
Toshiba 50H81 manual convergence
are you sure it's yoke? these are know for bad convergence amp ic's
other wise it's a screw and glue holding the yoke in place loose the screw and try to break the glue with out breaking the plastic on the yoke, the other thing you can do is adjust the magnets which have tabs on the yoke. i would mark the position's of everything on the tube with a sharpie so you can get it back to start.
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
