PA10JA048-H Payne Air Conditioner outside unit not working but is getting power from circuit breakers. Need help.
  • Roger Jelinek Apr 10, 2011
    Do you have and know how to use a meter? Thank you. Roger
    Scholar:
  • 133 Answers
Please read through the following and see if you can pin point the problem. Write back if you need with more information and I'll walk you through what ever you find. Roger
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
Posted on Apr 10, 2011
Testimonial: "Great info! Helped alot!"
  • Roger Jelinek Apr 12, 2011
    Thank you for the great vote. I'm here if you need me. Roger
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
Outside hvac unit
Check the breakers at the main panel flip them all the way off and back on. If this doesn't help check the outside breakers or diconnects near the units for power. Some disconnects have fuses or breakers so you may need to check these for power also.
Jul 29, 2010 | Ruud UBHC Air Conditioner
My amana ac unit over heats the circuit breaker and trips it off after running for about 15 minutes. It will not blow the fuses on the outside disconnect next to the unit outside.
What you described 'shouldn't' be happening - "if" the outside fuses and the inside breaker are sized correctly for your air conditioner.
I would make sure that the fuses in your outside disconnect were the proper size (for your AC), and that the inside breaker was of suffienct size to handle the air conditioner, and whatever else might be on the circuit.
Note: You would never want the 'outside fuse size' to be bigger than the inside breaker.
For example: 50 amp fuses in the outside disconnect and a 40 amp inside breaker is a no-no.
Often, for whatever reasons - someone will put larger fuses in the outside disconnect than what is called for.
When this happens the inside breaker is the only safety on the AC.
The problem is - for whatever reason - your inside breaker should not be tripping off.
It's likely that the AC may be on a inside breaker "that also has other things i.e. dryer, electric range or Refrigerator," and therefore any of these components 'including' the air conditioner could be causing the inside breaker to 'trip.'
One way to check this would be to 'un-plug' whatever else you had on the inside breaker - and then run your air conditioner and see if the breaker trips. Let's say you have the refrigerator and the air conditioner on the same inside breaker. You suspect the refrigerator is causing the inside breaker to trip - so you unplug it - and then turn on the air conditioner. "Now" it does not trip the inside breaker and assuming you have the proper fuses in the outside disconnect - you could safely say the air conditioner is ok - but - the refrigerator might be on the blink.
It's also possible that you just have too much on the inside breaker and you need to plug the refrigerator in to another outlet.
Still, if it was me - I think I would really think 'hard' about calling a Service Tech out - and let him/her diagnose the problem.
Hope this helps.
Jun 12, 2010 | Heating & Cooling
Inside fan running outside not
There is an electrical box on the wall near the outdoor unit. open it and be sure that the circuit breaker is in the on position. Same in your electrical panel, be sure that the circuit breaker is turned on.
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner not working
the outside condesor unit is not coming on for a number of possible reasons. First check your breakers for a tripped breaker, even if they appear on, turn the ac breakers off and then turn them back on. if after this, turn on the thermostat, outside you should here the contact switch on the condensor unit humming. if still no power, check for any breaks on your wires going in from the house, still nothing give a call back
Jun 24, 2008 | Ruud UAKA030 Air Conditioner
Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Sep 03, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
1,045 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
