Question about Minn Kota RipTide SM RT55/SM/L-D/SC Bow-Mount Trolling Motor
I have a minnkota riptide 55 sc. I have fishing line behing the prop and am wondering how the prop comes off. I removed the "zinc wing nut". The the prop slide off or does it spin off the threaded shaft with groved flat head end.
  • 605 Answers
The prop slides off with a shear pin behind it. Regards Phil
Posted on Apr 11, 2011
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    How to align the prop and nose (bottom) with the handle (top)
    FISH307 com Fishing Tackle Superstore
    This is a link that will allow you to look at a schematic for you motor.
    Minn Kota hand control motors have a small nut/bolt thru the motor shift aligning the handle with the lower unit. If yours does not line up your either missino this bolt or a previous owner altered the motor.
    Hope this helps.
    Oct 18, 2014 | Minn Kota Riptide St Saltwater 80 Bow...
    Prop spins when out of water but when i put it in the water it slows down to a slow creep
    yes very common, have you hit a rock as some stage or maybe it is wearing out but as soon as some pressure goes on the prop the shaft will spin normally but the prop is now no longer held to the shaft correctly hence your problem. Check it by marking the prop and shaft with a straight line then put it in the water, take out and check your mark they probably wont line up anymore. Solution...get a new prop. I have a different way to get these fixed but it is not recommended I drill a self tapping screw into my props just until it hits the drive shaft then stop just enough pressure to keep to stuck to the drive shaft
    Apr 09, 2014 | Minn Kota Riptide St Saltwater 55 Bow...
    Minn Kota rip tide st 55 very noisy
    is the prop shaft bent you may have busted a magnet in the motor dragging now
    Jan 20, 2013 | Minn Kota Riptide St Saltwater 55 Bow...
    Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
    Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
    Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
    Online manual needed
    I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
    Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Replacement of motorguide trolling motor prop
    Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
    Triton72
    Mar 26, 2009 | Boating
    Minn Kota RipTide SM RT55/SM/L-D/SC Bow-Mount Trolling Motor Logo
    233 people viewed this question
    Top Minn Kota Boating Experts
    Colin Stickland
    Colin Stickland
    Andrew Taylor
    Andrew Taylor
    Phil Walker
    Phil Walker
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
