Question about Garden
When trying to engage mower blades on my kubota zd21 zero turn mower the engine cuts off
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
  • 109 Answers
SOURCE: blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Posted on Apr 24, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
  • 760 Answers
SOURCE: I had just started cutting
You have several safety switches on your unit. The engine should not start if the PTO safety interlock is engaged. Be sure PTO switch is off.
If the sarter Does Not Work Or Will Not Turn Engine Brake pedal is not depressed.
or the PTO is engaged.
Battery terminals are corroded. or Fusible Link in starting circuit is blown - (Not likely unless bad wires) Here is a link to your wiring diagram (maybe your model)
http://www.postimage.org/image.php?v=Pq1tOfiS
Notice how the starting circuit goes through the brake pedal (must be depressed) and the PTO switch (must be disengaged) and that the PTO only works with operator present. Print that page while link still works.
Posted on Aug 11, 2010
WHERE CAN I GET AN OWNERS MANUAL FOR ZD21 KUBOTA MOWER
perhaps Kabota . my lawn tractor/mowers always came with one
Aug 23, 2015 | Kubota Garden
Why will my zd21 kubota zero turn mower pto clutch not engage
First check fuse. Then with a volt meter check for voltage on the 2 wires going to the PTO clutch with the key and pto switches on but motor off ( you may need to trigger the seat switch as well). IF voltage is detected the clutch its self is suspect. If no voltage then check for power into the PTO switch and then out of. If power in but not out then the PTO switch is suspect. And keep chasing voltage down the line until you find the failure. Voltage travels from key switch thru fuse, PTO, seat, and reverse switches to the clutch
Sep 01, 2014 | Garden
I have a kubota zd21 and every time I try to engage anything it dies what can it be
Change your air filter and plug. Otherwise, take it to a service center
Jul 26, 2014 | Kubota Garden
Repair manual Kubota ZD21
Here is a link for a free pdf manual download. I hope this is helpful.
http://www.imarkswebs.com/bk/free+kubota+zd21+repair+manual/
Sep 29, 2013 | Kubota Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Why does the engine of my Kubota ride on cut out when cutting
Sounds like you have a bad safety switch somewhere, possibly the seat switch.
Aug 10, 2012 | Kubota Garden
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Garden Logo
342 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
