Question about Clarion (DB165) CD Player
My car sterio stopes for 5 sec every5min - Clarion (DB165) CD Player
This is caused because of the Speed of your Cd, thats if u are playing a CD. For example a 48X Cd which is the speed that is marked on the CD can play on the Stereo, but perhaps a 52X cannot play as smooth as the 48X.
Posted on May 30, 2013
Have craftman lawn mover mod el 917378941 startes up lasts for 5-10 sec than stopes runing want service manual and owners manual. down load bill zuschlag at billzuschlag@yahoo.com
You have an obstruction in the carburetor. You will need to take it apart and clean it. Make sure to clear the little holes for the main jet. There are plenty of good examples of cleaning a carburetor on YouTube.
Sep 30, 2013 | Garden
I have accidentally locked the sterio of my Ford Focus 2001 Car while inserting a pin code. How do I unlock the sterio so that I can insert the correct pin code
disconnect + battery cable for 5 minutes and re-connect. that should reset the system completly so you can start all over again
Jan 13, 2011 | 2001 Ford Focus
Key fob stoped working, batteries replaced but still works using key to lock
unlock car with key/hold over for 30 secs,then lock/hold key over for 30 secs,then press remote unlock button for 30 secs,the car is now reset.
Apr 25, 2010 | 2003 Audi A4 Cabriolet
My radio stoped working. Battery not been
the sterio is damaged by heat, or the code is wrong.
Dec 16, 2009 | 2001 Ford Focus
HI ute just stoped fuel ok but not pumping put fuel down carby started 5 sec then stoped checked fueses ok. not sure where pump is. removed fuel fillter nothing any help would be great thanks tony.
fuel pump located on the frame in front of the fuel tank, just follow the metal fuel line back to tank. there just little electro magnets and a rubber diaphragm they do wear out. but for a short term fix. and to diagnose a few taps with a wrench may get it to rattle back to life for a short while
Nov 03, 2009 | 1986 Nissan King Cab
Ow do i hook it up to my home sterio system?
Not really possible, as a car amp requires a remote signal (usually a 'pulse' of 5 to 6 volts), to turn on.
Maybe you could wire up a small homemade battery/switch box to the amp to pride the switch on signal?
Apr 12, 2009 | Lightning Audio B4.250.2 Car Amp
Transmission stoped shifting from 3rd to overdrive
Your transmission is on limp mode and will not shift in to your 4th gear. Have it scaned and see what triggered the limp mode, Your can try resetting your ecm buy turning your ignition to the run postion and pulling the ecu fuse out for 5 sec and re-installing it. You'll hear the fuel pump buzz and then try starting it. Note the truck may start then stalls but let it, just start it up again and your should be fine. The ecm is recalibrating the it self again like the first day it was started. That should clear any limp mode for not. Good luck and get it scaned, could be as simple as a bad battery ground.
Apr 08, 2009 | 1999 Chevrolet Silverado 1500
Use the logitech sistem with lcd tv
hey no it wont work in full 5 .1 cuse samsung tv has rca outs use rca to mini sterio jack but your speakers syetm for pc is set up for fronts rears center chs 3 sepret sterio plugs for pc so u can only use one of these sets front with woof not all 5 nope unless ther was a controller in it that ran off 1 sterio plug to controll all 5 built into the logitec speakers but i pretty sure 3 sterio plugs right ? u understand best best dvd samsung x 40 those rock
Jan 09, 2008 | Logitech X-540 Computer Speakers
My tom tom go 700 don,t turn on
Hi I too had the same problem, the way I fixed it was to hold the rest button in for 15 secs than release and hold the on button in for 5 secs good luck mate!!!
Sep 12, 2007 | Tomtom GO 700 GPS Receiver
Clarion (DB165) CD Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
