Question about Canon iP100 Portable Printer
I have a portable Cannon IP100. The paper is not feeding and it is indicating a paper jam. Cannot access to see where the jam is. Do you have any suggestions?
Try to reset ...check back side of the printer..or clean the feed roller
Posted on Apr 10, 2011
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
The printer feed light is blinking orange. It blinks orange and than the power light blinks green, and then that repeats twice. I've tried re-feeding the paper but it's still not printing.
The paper feed rollers might be dirty. Please turn off the printer and clean the rollers with a soft rag with a little alcohol on it, wait a few minutes for the alcohol to dry and turn the printer back on.
Jul 07, 2015 | Canon iP100 Portable Printer
Always paper jam error on my cannon 3530
Check for a paper fragment at either end inside the printer chamber or underneath the paper feed roller cover plates. Anything that holds a paper feed sensor arm open will give you paper feed errors, and they can be remarkably small.
May 14, 2015 | Cannon Office Equipment & Supplies
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Printer paper is getting jammed What should I do?
First we have to have some drop of oil on to the support of the roller so that there must be a better lubrication and paper will be fine printed.
Mar 27, 2011 | Canon iP100 Portable Printer
How do I access the ink cartridges in my Cannon iP100?
Lift the top cover, which turns into the paper feed tray, and the front cover, which hides the output slot, drops down.
There's a second top cover, which presents the means to access the twin ink cartridges.
Open this second top cover when the printer is on, and the ink cartridges will move over allowing you to access them.
Hope this helps!
Mar 09, 2011 | Canon iP100 Portable Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
My ip100 printer keeps displaying paper jam when there is no paper in the printer
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 10, 2009 | Canon iP100 Portable Printer
PIXMA iP100 portable printer
i'm sending a link so you can find a service location in your area. you have to enter you zip and info i don't have. your going to probably need that part. have a great day and if i can be of more help reply for bama46. remember to rate bama46, thanks http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=257&modelid=16505
Aug 22, 2009 | Canon PIXMA iP100v + lithium battery...
Printer will not print. I have a canon ip100. I get error message 311.
if you have the cd that came with it,, unistall and reinstall,, if not go to cannon site and dowload printer files
Aug 11, 2009 | Canon iP100 Portable Printer
Canon iP100 Portable Printer  Logo
1,016 people viewed this question
old marine
old marine
