Question about Harman Kardon SoundSticks II Computer Speakers
Coins and cereal inside the bass enclosure. how to open.
Use a razor knife and cut the adhesive along the seam open it up remove coins and cereal use a couple drops of super glue put it back together
Posted on Apr 15, 2011
Trying to connect peavey tour 700 to a trace elliot 1518 bass enclosure. Plug the enclosure to the back of the amp. Then plugged my bass into the high gain. Turned it on and nothing happens.
Check continuity on all cables, try a different cabinet with the head and a different head with the cabinet and the bass with a different rig to see which part of the chain isn't working, make sure the volume controls are turned up on both the amp and bass. Once the problem is narrowed down it will be easier to advise you.
Oct 12, 2014 | Music
What is the best enclosure for the diamond audio tdx12d2 subwoofer
Personally for a sealed box i would go with at least 1.2 cubic feet inside volume.
A 19" x 14" x 17" box will give you a volume of 1.6 cubic feet (most common).
You can do the math by H x W x D then divide that # by 1728 (for 12" speaker) to get your enclosure volume (cubic feet).
The best enclosure depends on what your looking for in bass response.
Jul 05, 2014 | Diamond Audio TDX-12D2 Car Subwoofer
Should I use a vented box or a non vented box for my ALpha PSW412
Well, First you need to figure out a few things. How much room you have is one main consideration, If you go with a vented (ported) enclosure or band pass (see below) than you will need more room than with a seal enclosure, If you really have no room you can mount them " Free Air" which is mounted on a board and fired into the back seats, the Truck acts as the enclosure.
Now the type of bass you want is another consideration. The best enclosure for maximum bass is a bandpass box. It is 2 subs facing each other with one side fully enclosed and the other side ported. This is best for deep powerful bass but the enclosure can be rather large. Vented boxes are second best (In my opinion) they give you deeper bass and more power than the sealed boxes. Sealed boxes give you less power from your sub and are a little flatter. Some say that the bass is more accurate and tighter , depending on the type of music you play. Rock you would want a tighter bass(sealed) and hip hop or techno style you would want a deep bass(ported). Lastly you have the free air which gives you the least amount of bass and is usually rather flat sounding. If you have the room go for the band pass box, if room is an issue than go with a sealed and specifically design box for you vehicle. Alot of places design boxes for almost every car out there. Just make sure that have a well designed box, It makes a world of difference, than an improper box.
May 22, 2010 | Alphasonik PSW412 Car Subwoofer
I own a hk 12x2 and put it in a 2 cube inch sealed enclosure. will it sound better in a ported or bandbass
ported is the loudest your going to get as you get sound from the front and the rear of the sub compared to hearing only one side in a sealed or bandpass box.Bandpass boxes are very loud near there tuning frequency but tend to sound offish at tones that aren't near the tuning frequency. The same with ported boxes and the bass will tend to be a little sloppier compared to the tight bass of a sealed enclosure- it comes down to your musical preferences- more sound at the cost of clarity and loss of power handling capability or tighter cleaner bass with added power handling.
Jan 01, 2010 | MA Audio HK12X2 Car Subwoofer
What enclosure do i need for cerwin vega v-max 124 12" sub
Just get a 12" sub box enclosure for an audio store near you or make a custom box, a larger box supposedly gives you more bass yet at the cost of boot space. I have a type R sub and the box is only as big as it needs to be for the sub to fit and it gives amazing bass.
Aug 04, 2009 | Cerwin Vega V-Max 12 Car Subwoofer
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
Bass sounds muddy and volume is minimum.
Hello mercedesman4,
Your setup sounds great. I had to settle for Blaupunkt in my Mercedes.
It sounds like the culprit is your enclosure. It's possible that by tweaking the settings, you could improve the sound somewhat, but having been used to the sound of a sealed enclosure, maybe not. Sealed enclosures tend to produce tighter, more accurate bass and have a flatter frequency response curve. They are also generally the enclosure of choice when looking for a SQ (sound quality) oriented setup.
Ported enclosures will produce louder bass than sealed enclosures, and maybe that's why some audio guys push them. They also allow the speaker to operate more efficiently, so you need less amp power for a given volume. Higher tuning on a ported box will get louder, but at the expense of sound quality. Lower tuning will still get louder than a sealed box, and the sound quality will be better than a box tuned higher, but still not as good as sealed. That's what I meant about tweaking the settings. You may see some improvement by setting the crossover lower, decreasing bass boost, or by turning the subsonic filter on/off. I'm no audiophile, but personally I've never been able to stand the sound of a ported enclosure, however it was tuned. Sealed just sounds better.
Hope this helps.
Mar 30, 2009 | Car Audio & Video
Bass not Very deep
250 watts rms seems a little low for a 12 inch woofer, a 500 or higher will likely fix your problem. Specific model numbers and the type of enclosure you have will allow a more specific answer.
Mar 17, 2009 | Car Audio & Video
Enclosure type
Sealed box and somewhat large if they are 12's I usually try to get 3 cubic feet overall internal dimensions and generally the inside dimensions will be 13" tall 32" wide and 13"-14" inches deep. with no divider and make sure the box is sealed. Personally I like to phase the speakers backwards. Gives the bass a little more rumble.
Jan 05, 2007 | Sony XS-L1200B Car Subwoofer
Harman Kardon SoundSticks II Computer Speakers Logo
170 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
