SOURCE: Salesperson cracked the crystal on my Anne Klein watch.
the sales person should replace it . but some horolgists have a machine that cuts new glass. hope this helps joe
SOURCE: Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
SOURCE: I can't get the back off of my Anne Klein watch
Take your watch to your nearest watch shop and ask them to do it for
you.
You can get into difficulty replacing batteries and it is
not worth the risk for the small cost saving in doing it yourself.
SOURCE: how do i take the
If it's a pop-off type back, (you can tell by running your finger nail around the edge between the back and the case) If you find a slight indent or flat spot near the 12 o'clock position it is a pop-off back. Use a very sharp blade and VERY gently pry the case back up at this spot. It should pop off easily. Don't force it or it'll bend. To replace: line it up in the same position it had been and apply firm pressure untill it snaps back. If it's a screw off back (it has a series of slots around the edge) you'll need a case back tool to remove it. In that case it'll be easier to go to a jeweler.
Testimonial: "very good"
