Question about Maxi-Cosi Priori XP Booster Car Seat - Black
How do you move shoulder straps up?? - Maxi-Cosi Priori XP Booster Car Seat - Black
  • Maxi-Cosi Master
  • 1,629 Answers
Hi Linda - Instructions are in your user manual. If you have lost your user manual a replacement can be downloaded at www.maxi-cosi.com
Posted on Nov 29, 2011
What is a sternum strap?
The sternum strap only purpose provides stability and keeps the shoulder straps in place.
Sep 06, 2012 | Burton Camping, Backpacking & Hiking
My 2 year old can get out of bugaboo even though she is strapped in? Is there extra straps or a harness for bugaboo
The Bugaboo's like 99% of all strollers have a 5 point harness. Two shoulder straps Two Lap straps and a center strap with the main body of the buckles. 2 year olds become little Houdini's pulling the shoulder straps off in both strollers and car seats. There are small buckle units you can buy that lock the two shoulder straps at chest height these are excellent at keeping kids in their place. Ask any nursery supply shop they should have them.
Oct 10, 2011 | Bugaboo Baby Gear
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
I am trying to refit the straps on a britax car seat (For children 9-18kg) but I cannot get the straps attached to shoulder pads positioned so they are on top of the shoulder straps when coming through the...
hi here is a manual for the eclipse version i have a first class and mine fit the same way so assume they all fit like this, if this doesnt work i will try to help further I know how to do it but cant explain in words
click here anyway worth a try
http://www.britax.co.uk/media/142518/11.pdf
Feb 07, 2011 | Baby Gear
The automated shoulder strap part of the driver side seat belt will not move to position over the shoulder
pull the strap out till it stops it probably just has a twist in it tightening the retractor
Jan 03, 2011 | 1989 Toyota Camry
Please can you tell me how to alter the shoulder straps. I would like to move the straps up to the centre position on the back of the child seat. Can you help?
open the little door behind the seat back, unhook teh straps from teh metal holder. Pull one side out completely from the back of teh chair and the shoulder pad.
Thread the free pad into the back of teh seat then out to teh front on teh other side,
Reverse the above but at the height you want
takes about 3 minutes
Nov 09, 2009 | Maxi-Cosi Priori
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Maxi-Cosi Priori XP Booster Car Seat - Black Logo
108 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
