Question about Garden
1997 MTD Yardman 20hp 46in, hard starting,needs jump even with new batt; brothers mtd had similar problem, shop adjusted valves; prosedure for valve adj?
    Genius:
  • 1,267 Answers
Time to clean the carburetor as the alcohol laced fuel sold today causes gunk to build up in the orifices of the carburetor and degrades fuel flow. You may want to add a little fuel cleaner such as Sea Foam (sold at Walmart) or any other type of cleaner to try and mitigate the starting problem. You may also want to drain the fuel when storing the machine for any length of time or add Stabil to the fuel which works fairly well.
Posted on Apr 10, 2011
My two stage snow thrower MTD Briggs & Stratton motor, Start well but after 20 minutes it stops by itself when hot and unable to restart it until it cool off. Could it be the pick up coil defective?
no
more likely valve clearance adjustment
B&S engines stretch the valve stems and when hot the valves to not seat properly and are hard to start until the valve stems cool and the clearance allows the valves to seat properly
coil problems will fail earlier
Jan 11, 2018 | Mtd Garden
I have a model 600-699 1998 MTD 46in YARD MACHINE. Is it possible to check/add fluid to the trans axle?
I had a 1999 yard machine that did the same thing i had to replace the transmission it was still working when i sold it this year
Sep 04, 2017 | Mtd Garden
Can anyone help me and tell me the part number for a blade for a dx70 Mtd yardman 8.5cc
Duncan, Blade #, MTD Part No 742-0578, 27.5" should be replacement bade for Yardman DX70. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GENUINE 27 5 Blade for Yardman DX70 MTD Beatle Lawnflite 503G Ride on Mower
YARDMAN DX70 MODEL 310 SINGLE BLADE MOWING DECK FG424 5900
Yard Man 13A 325 402 Operator Manual
May 21, 2016 | Mtd Garden
20hp Tecumseh ohv ajustment
I have found a video that should be very similar to adjust the 20hp engine. Need to know the specs for clearance too.
https://www.youtube.com/watch?v=CSZ_gYUDUwA
Jul 07, 2015 | Mtd Garden
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
MTD yard machine model 668 (46in) does not engage
check your brake pins on the trany there rusted and sticking. you can also shoot some wd-40 and hit your bake pedal till ti comes loss. now if you still can't use low dear check your variable speed pulley assay. may need to be replaced or rusted too. check for missing spring too. adjustment may be needed
Sep 26, 2009 | Mtd Garden
Tranmission is hard shifting
Check the linkage to see if it's free and not stuck in any way. Also, where it's old it may need a couple adjustments on the rod located under the unit.
Aug 23, 2009 | Mtd LAWN MOWER PART # 17871D FENDER-REAR...
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mdt 16.5hp wil not turn over fast enough to start engine
The valves need adjusting. They are too loose and bypassing the compression release on the cam when trying to start.
Jun 19, 2009 | Mtd Garden
Garden Logo
178 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
