Avaya 1603I IP Phone 1 x RJ45 10100BaseTX PoE Desktop (700476849) Logo
Posted on Apr 10, 2011
I have 1603-I phone, it dosent work when i connect it to PoE switch what is the solution??
2answers
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
How to resolve PoE fault hp5400zl
Those switches have a lifetime replacement warranty. Find the number you need on this website: http://www8.hp.com/us/en/contact-hp/phone-assist.html
and have the serial number of the switch handy. have the switch plugged in and running and have a laptop and a console cable ready before you get HP on the phone. If it comes down to being a problem with a part they will either send you the part you need OR the whole switch depending on what the problem is with the switch. Most PoE faults are power supply problems. if your switch has more than one power supply be sure the connect both of them to power as HP POE switches that have more than one power supply, 1 power supply gives power to a certain portion of ports and the other power supply will give power to another portion of the ports. Much good luck!
PoE Cable for Polycom IP 500
Check if the switch uses active or passive PoE and the volts it pushes out
Active(PINS)1 2 3 4 5 6 7 8RX/DC+ RX/DC+ TX/DC- n/a n/a TX/DC-
Passive(PINS)1 2 3 4 5 6 7 8RX RX TX DC+ DC+ TX DC- DC-
Cat 5 cable9V < 30m cable length12V < 60m cable length
Max Ethernet cable length is 100m
2answers
Hello, my cisco ip phone does not start
Confirm if the Phone has power supply. and If it's connected to a POE switch confirm that it connects to the Switch port on the phone.
One way audio on NEC ITL 12 button IP Phone at remote site. Main site has IP Phones which are working fine. IP Phone connected to Cisco 3560 24 port poe switch. Switch connected to 2801 router. Point to...
This is likely a config problem on the NEC or a hardware/software issue on the NEC. Do a Wireshark capture on the NIC on both ends. Examine the RTP streams and see if they are intact. You may have to decode the stream from UDP to RTP depending on if it is a peer to peer call or if it is going through the 8100. Plenty of documentation on how to do that at Wireshark's website.
2answers
Can I use the Alcatel OmniAccess 4012 as a regular simple network switch to create a small pc network? It is a small office that will be using POE IP Phones and 12 PCs. Is posible to configure this...
Yes, the switch provides what you need for the 12 PCs. As far as the POE IP phones, they will work only if powered by another source. The switch will not feed them power. A larger switch such as a Cisco with POE blades would be needed.
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
