Question about Grilling
Carbourater for a tecumseh engine
I nedd to know where the needles need tro be fixed at in the carb because it keeps stalling. i need to know the specs for it. i have the numbers off the engine.
thanks,
totally frustrated
Start by closing jets (clockwise). Then turn jets 1 full turn counterclockwise. this should get engine started. Then adjust jets left or right to fine tune,until engine starts running smoothly.
Posted on Aug 10, 2008
SOURCE:
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
Tecumseh engine snowblower, will only run if I keep pushing the primer bulb, Why?
Take off the screw that holds the carburetor bowl on and clean the holes with a needle and blow air through them. These holes feed gas from thr bowl into the carb and may be clogged.
Feb 23, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Lawn mower starts then stalls
if you have a Tecumseh engine the main jet is plugged and you are starting on primer fuel. The jet is located in the bowl nut of the carb. Blast all holes with cleaner and air. You may need to find a small needle, ones used to hem clothes, and run that through to loosen stubborn particles and rinse out. let us all know if this works or you have a briggs motor.
Aug 30, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Tecumseh 10hp snowblower
Sounds like carburetor needs a good cleaning.
Dec 27, 2011 | Tecumseh Snowblower Snow Blower Starter...
Surging tecumseh engine on snow blower
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
Jan 30, 2009 | Garden
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Ariens snowblower ST724 leaks gas from the carbourater
The little metal peice with the wire ataches to the float at the hinge part of the float, if you use yahoo type in tecumseh carburetor diagram then click on Parts and Diagrams and the web address is partstree.com it will show you a breakdown of a carb and how it goes together. It may not bee your exact carb but they are all pretty much the same. It also sounds like you may need to rebuild your carb. If you get it back together and it still leaks, I suggest you take it to a small engine repair shop and have them rebuild it for you only cause you need a special tool for the seat and the float will have to be set.
Dec 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Grilling Logo
413 people viewed this question
Top Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a Grilling Expert? Answer questions, earn points and help others
