Question about Paradigm Titan Speaker
My daughter pushed in the cone on my Paradigm Subwoofer and would like to know if that can be repaired, it just need to be poped back out if possible. Thanks for your time and I look forward to your call. Tommy Jackson 512-246-7777 ofc 512-568-4686 mob.
    Brigadier General:
  • 8,546 Answers
If it's just the center dust cover and you have no audible symptoms don't worry about it.
http://www.ehow.com/how_6933063_repair-speaker-dust-cap.html
Posted on Apr 10, 2011
What is the impedance of the 12" driver in this subwoofer
PS-1200 Specifications
Design
Single driver, DCBS™ system with high velocity resistive ports and built-in amplifier Amplifier High current, hybrid output, 130 watts RMS
Amplifier Features Powersaver auto-on/off, soft clipping, thermal protection Low Pass Filter Frequency Variable 50Hz-150Hz Low Frequency Driver 310 mm, carbon-fiber-reinforced composite cone, Apical™ former Low Frequency Extension 23 Hz (DIN) Sub / Sat Phase Alignment 0 - 180 Finishes Black Ash Inputs From A/V receiver/processor or Paradigm X-Series Control Unit or preamp left/right output; From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 68 lbs. (31 kg) Dimensions HxWxD 19.75" × 17" × 21"
(50cm × 43cm × 53cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Apr 26, 2016 | Paradigm PS 1200 Speaker
What would cause paradigm sub12 not to power on
The inside of a subwoofer isn't really a great place to put an amplifier, that that is what you have. These things do go bad from time to time.
You may be able to get it repaired, or you could replace the amp. You're looking for a "plate amp". Parts Express has a good selection:
Subwoofer Plate Amplifiers
Oct 14, 2015 | Paradigm Audio Players & Recorders
My Paradigm PDR-10 subwoofer needs a new fuse (1.5amp 250v) but I cant find the physical location of the fuse on the sub anywhere. Ive looked at it for a long time now. Any help? Thanks, Bryan Tal
Try right behind the power panel. Certain models you have to remove amplifier back panel. Then some are soldered on and some are encased in some kind of holder usually by the power input. Be carefull of electric shock. Make sure device is un-plugged while powered on to help with discharging internal capacitors if possible or drain caps with appropriate resistor to drain them safely if possible.
Nov 17, 2014 | Audio Players & Recorders
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
I have two jl audio 12 w6v2 running with a jl audio 1000/1 and at high volume they make a poping noise does any one know y
That popping noise is your speaker telling you to turn it down, and that your amp is too powerful for your setup. The speaker cone is moving beyond its limits of excursion and on it's way to malfunction/blown. Basically the voice coil will fry.
Mar 16, 2010 | Jl Audio 12W7 Car Subwoofer
PDR-10 subwoofer has no output. 120vac to unit is
I have exactly the same situation with my PDR-10. Paradigm techs were of no help, don't me to take it to a service centre which i did. Of course when it was there they plugged it in and it stayed on for a day and a half so no problem right? Get it home, nothing, plugged and replugged, got it on once but not for long. Opened up back, everything including fuse looks solid and fine....to naked eye anyhow.
Dec 20, 2009 | Paradigm PDR 10 Speaker
Subwoofer replacing,
Hi , try visit : www.Shopping .com
May 06, 2008 | Car Audio & Video
Voice coils
Hello. I do speaker reconing and amp rebuilds for a living and the L7's often suffer from tinsel leed wire breakage which can cause "poping" and "screaching" noises in the sub in various cone positions. You need to remove the sub and push straight down on the cone repeatly and determine if you can feel or hear crunching noises to make sure the voice coil and/or spider are not damaged. A faulty leed wire can usually be identified by a dark spot or obvious breakage. All of the L5 and L7 models can be successfully repaired as long as they are the older models that have a center cap in the cone. The newer capless models will have to have an upper brace cap glued to all of the cone's fingers and will have a rather ugly appearance. Leed wire overhauls usually run around $30.00 for the older models. Voice coil and spider overhauls run around $90.00.
Dec 12, 2007 | Kicker 02S10L74 Car Subwoofer
Paradigm Titan Speaker Logo
493 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
