Question about Welding Tools
Mig welder started to arc out on its own. You dont touch the trigger and when you put the wire to the grounded table it blinds the **** out of you. Could use some tips on repair. Thanx. Shane.
    Genius:
  • 1,267 Answers
Try replacing the feed tip as this is an insulator that keeps the wire from touching the tip as it feeds out. These tips need replacing often as they also provide a friction free surface for the feed wire.
Posted on Apr 10, 2011
Repair mig welder
Control circuit failure or blown fuse on low voltage power supply. Look for 24VAC transformer. If that is OK follow to the trigger contactor and see if it is disconnected, burnt, etc.
Aug 28, 2014 | Welding Tools
MY CLARKE WELD 235 TEN TURBO ARC WELDER HAS SUDENLY STARTED BLOWING FUSES WHEN IT ARCS UP ANY IDEA
More then likely you have a shorted component (positive or hot wire to ground). Verify that the gun/trigger assembly is in good shape and has no broken wires that are touching the ground or case (may have to disassemble). Thats the easiest thing to check, everything else is inside the unit and will take more sophisticated knowledge and equipment to diagnose.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
No arc/ no burn
You need to inspect the ground.Where it connects to the machine, and at the end. I bet one of the connections or the wire itself is damaged.
Jul 20, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
116 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
