Question about Spy Gear Ultimate Watch
I got this spy watch XP-6 from spy-gear(brand name). I need to know whether it is water resistant or not. If yes, how many meters is its water resistance. Thanks in advance. (:
Is the fossil fs4813 waterproof
yes, to 50 metres
Fossil Men's FS4813 Grant Stainless Steel Watch with Leather Band ...
https://www.amazon.ca/Fossil-FS4813-Grant-Stainless-Leather/dp/B00AFTTQ8I
Rating: 4.5 - ‎50 reviews
Tang clasp. Water resistant at 50 meters / 165 feet. Casual watch style. Fossil Grant Chronograph Black Dial Brown Leather Mens Watch FS4813.
Grant Chronograph Brown Leather Watch - Fossil
https://www.fossil.com/us/.../grant-chronograph-brown-leather-watch-sku-fs4813p.ht... Rating: 4.6 - ‎91 reviews - ‎US$115.00 - ‎In stock
PRODUCT DETAILS. Collection: Grant. Movement Type: Quartz Chronograph. Case Size: 44mm. Strap Material: Genuine Leather. Water Resistant: 5 ATM ...
Water Resistant Watches, 10 ATM Watches ' FOSSIL
https://www.fossil.com/us/en/******/10-atm-watch.html Water Resistant Watches up to 10 ATM. Fossil Hybrid Smartwatch - Q Nate Dark Brown Leather Ftw1114. Quick Look. Fossil Hybrid Smartwatch
Is the fossil fs4813 waterproof Google Search
Aug 16, 2017 | Fossil Watches
How do I replace the Secret Paper for the Ultimate Spy watch
Dear Spy Watch User,
Refill paper for the Ultimate Spy Watch can be found here: http://www.wildplanet.com/help/instructions/spyMessageShredderPaper.pdf.
It's best to use a color printer. And you can save the paper file for your next refill!
If you ever need help with Spy Gear products you can email us at help@wildplanet.com or call us at 800.247.6570.
Jun 05, 2011 | Spy Gear Ultimate Watch
I have just purchased a Clarement (nice watch by the way). My question is that the manual with the watch says that if "water resistant" is etched on the back of the watch then swimmimg is a...
Water resistant up to 90 meters means that the watch can survive a fall of 90 meters in water level.You cannot swim while wearing the watch because it can let water into the watch due to over exposure to water.
Mar 21, 2011 | Quorum 23565-93 Clairemont Charcoal Fan
Can I swim laps w/ my ebel 30 meter watch? The watch has 4 screws on the back and the crown does not screw down.
Thank you for contacting FixYa.
Water Resistant is a common mark stamped on the back of wrist watches to indicate how well a watch is sealed against ingress of water. It is usually accompanied by an indication of the static test pressure that a sample of newly manufactured watches was exposed to in a leakage test. The test pressure can be indicated either directly in bars, or (more commonly) as an equivalent water depth in meters (in the United States sometimes also in feet).
An indication of the test pressure in terms of water depth does not mean a water resistant watch was designed for repeated long term use in such water depths. For example, a water resistant watch marked at 30 meters depth cannot be expected to withstand activity for longer time periods in a swimming pool, let alone continue to function at 30 meters under water. This is because the test is conducted only once using static pressure on some of the newly manufactured watches. The test for qualifying a diving watch for repeated usage in a given depth includes safety margins to take factors in account like aging of the seals, rapidly changing water pressure and temperature, as well as dynamic mechanical stresses encountered by a watch. Also every diving watch has to be fully tested for water resistance.
Hope this helps.
Jewel
Sep 02, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
How water resistent is watch??? Anyone with experience?? How about after battery replacement?
mcdevito 75 here, Usually 50--100 meters of water resistance on brand new watches. However after a battery change, unless you also change the gasket (rubber ring) on the cover, you could loose all water resistance capability.
May 28, 2010 | Casio AWS90D-2AV Wrist Watch
My Casio G-shock says water 20BAR resist.Is this 50,100,or 200 meters water resist?
1 bar = 10 meters (approximately).
So a 20 Bar watch is resistant to 200meters.
Apr 17, 2010 | Casio G Shock #DW6900FS 8 Watch for Men
I would like to know if the casio 3736 watch is water resistant because I found only the phrase water resistant 5bar
"Water resistant 5 bar" means that it is water resistant to and depth of 50 meters. (1 bar is approximately equal to 10 meters of water depth).
Apr 09, 2010 | Watches
My Polar F6 is not water resistant like it's supposed to be??????
Your watch is water resistant...not water proof...which means if you get a little water on it, fine..but certainly not wearing it in the pool!
Jun 28, 2009 | Polar F6 Wrist Watch
Can i dive with this watch?
You definetely CAN NOT dive with this watch. It is good for swimming and snorkeling only. Real divers watches withstand at least 200 meters of depths and are specialy designed for it.
One of the best affordable divers watch manufacturers novadays is Seiko. Check Seiko website and learn about divers watches and all the features they have. List of waterproof markings and explanations are also available.
Do not forget to rate, please.
Feb 12, 2009 | Casio W752V3AV men's watch
Spy Gear Ultimate Watch Logo
162 people viewed this question
Top Spy Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Spy Toy Expert? Answer questions, earn points and help others
